Bead sliding on a rigid straight wire
A bead slides along a rotating wire tilted at angle α, governed by the equation of motion \ddot{q} - ω²sin²(α)q = -gcos(α). The proposed solution involves an ansatz q = Ae^{Bt}, leading to a simplified expression that lacks time dependence, indicating a mistake in the approach. A suggested linear substitution transforms the equation, allowing for a new variable p(t) that leads to a general solution involving exponential terms. To fully determine the specific solution for q(t), two initial conditions, including q(0) and \dot{q}(0), are necessary. The discussion emphasizes the importance of these conditions in solving the differential equation accurately.
Favicon
A bead is free to slide along a rigid, straight wire, whilst the wire is rotating at angular velocity ω about the z-axis and is tilted away from the z-axis at angle α. I have the equation of motion (EOM) and need to find an explicit solution for the distance of the bead along the wire (q) as a function of time.
EOM: \ddot{q} - ω^2sin^2(α)q = -gcos(α)
I assume the ansatz
q = Ae^{Bt}
which differentiates twice to give
\ddot{q} = B^2q
and substitute the second expression into the EOM, which gives (after a little rearrangement):
q = -\frac{gcos(α)}{B^2 - ω^2sin^2(α)}
I don't know what I've done wrong, but I'm sure I must have made a mistake somewhere since the result is an expression for q which has no dependence on time, despite my ansatz that q is a function of time. Can anyone explain what I should do differently here?
Hi Favicon! :smile:
I assume the ansatz
q = Ae^{Bt}
\ddot{q} = B^2q
no, it's AeBt = that
but wouldn't it be simpler to write \ddot{q} - ω^2sin^2(α)(q + gcos(α)/ω^2sin^2(α)), and make the obvious linear substitution? :wink:
tiny-tim said:
Hi Favicon! :smile:
Please bear with me as I'm quite rusty on my differential equation solving. By "the obvious linear substitution" I take it you mean p(t) = q(t) + \frac{gcos(\alpha)}{\omega^2sin^2(\alpha)}
Then, since \alpha and \omega are both constant, we have \ddot{p} = \ddot{q}
Substituting those into the EOM (in the form you suggested) gives
\ddot{p} - \omega^2sin^2(\alpha)p = 0
No I take the ansatz p = Ae^{Bt} and substitute into the previous equation to get
B^2Ae^{Bt} - \omega^2sin^2(\alpha)Ae^{Bt} = 0
B = ±\omega sin(\alpha)
If I remember rightly, this means a general solution takes the form
p(t) = A_1e^{\omega sin(\alpha)t} + A_2e^{-\omega sin(\alpha)t}
Substituting for q then yields
q(t) = A_1e^{\omega sin(\alpha)t} + A_2e^{-\omega sin(\alpha)t} - \frac{gcos(\alpha)}{\omega^2sin^2(\alpha)}
Am I right so far? I can see that to go any further would require knowledge of q(t) at some specific time, e.g q(0). However, the textbook from which I'm working suggests that to determine a specific solution for q(t) would require knowledge of \dot{q}(0) at some specific time also. Where does this requirement come from?
yes :smile:
now you have two constants of integration, A1 and A2, so you need two initial conditions to find both (which will usually be a condition on q and a condition on q')
Ah yes, that's a good point. Thanks very much for your help Tiny :)
  • · Replies 17 ·
  • · Replies 37 ·
  • · Replies 23 ·
