Beaglebone simple data acquisition system?
In summary, a Beaglebone simple data acquisition system is a small and affordable computer board used for data acquisition and control purposes in scientific and engineering projects. It works by connecting to sensors and devices and can acquire a wide range of data, including temperature, pressure, and motion. It also has a user-friendly interface and can be easily programmed using different languages. Its low cost and compact size make it suitable for budget and space-limited projects, and it can be expanded with add-on boards for specific applications. Common uses for a Beaglebone simple data acquisition system include environmental monitoring, home automation, robotics, scientific research, and educational purposes.
M Quack
893
67
Is anybody here using the Beaglebone SBC?
http://beagleboard.org/bone
I want to build a simple data acquisition system that reads 4 analog voltages (0-10V),
does some simple math (e.g. difference divided by sum of 2 channels) and provides a device server so that the raw and calculated values can be read (polled) over Ethernet.
Nothing fancy. At first sight it just needs a few voltage dividers and a few lines of software. I'm just wondering if anybody has already done something similar. I hate to reinvent the wheel
heck no, dataq
FAQ: Beaglebone simple data acquisition system?
1. What is a Beaglebone simple data acquisition system?
A Beaglebone simple data acquisition system is a small, low-cost computer board designed for data acquisition and control applications. It is often used in scientific research and engineering projects to collect and analyze data from various sensors and devices.
2. How does a Beaglebone simple data acquisition system work?
The Beaglebone simple data acquisition system works by connecting to sensors and devices through its GPIO pins, USB ports, or serial ports. It then reads and stores data from these sources, and can also send control signals to devices if needed. The data can be accessed and analyzed through the Beaglebone's software interface.
3. What kind of data can be acquired using a Beaglebone simple data acquisition system?
A Beaglebone simple data acquisition system can acquire a wide range of data, including temperature, pressure, humidity, light, sound, motion, and more. It can also interface with devices such as motors, actuators, and relays for control applications.
4. What are the benefits of using a Beaglebone simple data acquisition system?
One of the main benefits of using a Beaglebone simple data acquisition system is its low cost and small size, making it ideal for projects with limited budgets and space. It also has a user-friendly interface and can be easily programmed using various programming languages. Additionally, it is highly customizable and can be expanded with add-on boards for specific applications.
5. What are some common applications of a Beaglebone simple data acquisition system?
A Beaglebone simple data acquisition system can be used in various applications, including environmental monitoring, home automation, robotics, scientific research, and industrial control systems. It is also commonly used in educational settings for teaching students about data acquisition and control systems.
