Beam calculations - Simply supported vs pinned both sides
In summary, a pinned connection resists rotation at the support, while a simple support can take a load only in one direction. A single pin connection is standard on many smaller H-frame presses (I'm looking at 40-tons or less).
Turbine
Hi guys,
Hopefully a fairly simple question. All beam formulas I've come across, whether in my own textbooks or Machinery's Handbook, have two sets of formulas for beams. One will be for "simply supported", where one end is pinned and the other end is a pin-roller. The other connection type is simply "fixed". Where would a beam connection fall among those which has ends that are both pinned without "rollers". Basically I'm analyzing a horizontal steel beam pinned between two vertical beams.
Example:
This very well is just a "simply supported" example, my only hesitation is knowing that there will be no horizontal translation in my design, whereas in traditionally "simply supported" situation, there is horiz. translation due to the the roller. Hopefully someone can set me straight. Thank you!
A pinned connection can take a load applied in any direction; a simple support can take a load only in one direction (usually vertical). The rollers on a simple support allow a beam to grow or shrink (usually due to temperature differences) without loading up in the axial direction (think of expansion joints in roads and bridges).
You diagram is not clear enough to determine if the horizontal beam is restrained against rotation at the ends or not. If the pins were actually bolts or rivets, you could make the case that this beam is fixed at each end.
Supports are generally idealized to allow for an analysis of some sort. Analyzing beams using actual support conditions and configurations is a little messier.
Thank you for the quick response. In the diagram, those "pins" are literally just that, about 1-1/4" diameter steel rods. The beam is about 48" long. Application is a hydraulic press. I could just as well design it with a pin support underneath one end of the beam to act as a roller, which would precisely fit the "simply supported" equations.
It's not clear how big a hydraulic press we are talking about here, nor how this structure goes with it. Using a single pin at each end of the horizontal beam may also not be advisable.
I will warn you that if you are not a mechanical engineer or a machine designer, you shouldn't be using formulas picked up out of a handbook unless you fully understand the limitations of their application.
The size isn't a factor in this question, simply trying to understand the differences in the called-out supports. As for press designs, a single pin connection is standard on many smaller H-frame presses (I'm looking at 40-tons or less). This allows for an adjustable lower platform. I am a returning student (former aviation professional), now a senior undergraduate mechanical engineering major. I'm doing this a an exercise in engineering to refresh on some of these topics. I've done plenty of shear/moment diagrams in years past, bending calculations, bearing stress, etc. But trying to apply textbook problems to real-world situations isn't as cut-and-dry. I'm still learning, by no means have I mastered the material (obviously), and I certainly appreciate your advice.
From my understanding, a fixed support resists any rotation at the support, in contrast to pinned connections that do allow rotation. The confusing difference is between pinned supports with rollers and without. A rollers allow translation along the x-axis, whereas a simply pinned connection does not, yet still allows rotation. Therefore the stress, I'd imagine, will be different, and this is precisely where I'm lacking clarity.
For example, looking at max deflection using my above drawn example. Given a single point load, deflections for two support instances are:
Supported at both ends: WL^3/48EI
Fixed at both ends: WL^3/192EI
(Source: Machinery's Handbook)
Clearly the fixed-support case will have the least deflection. But if the ends are pinned and can NOT translate along the x-axis (as I believe the "supported at both ends" case assumes can occur), yet the ends can rotate unlike fixed-ends, then the deflection would really be in between the two formulas. How does one account for that? Of course I could assume worst case (and perhaps that's what you do), but I'd imagine this has got to be a fairly standard case.
Related to Beam calculations - Simply supported vs pinned both sides
1. What is the difference between simply supported and pinned both sides beams?
Simply supported beams have fixed supports at both ends, while pinned both sides beams have pin connections at both ends. This means that simply supported beams can rotate at the supports, while pinned both sides beams cannot.
2. How do I determine the reactions at the supports for a simply supported or pinned both sides beam?
The reactions at the supports can be determined by using the equations of static equilibrium. This involves taking the sum of forces and moments at each support and setting them equal to zero.
3. Which type of beam is stronger, simply supported or pinned both sides?
The strength of a beam depends on various factors such as the material and dimensions. However, in general, pinned both sides beams are stronger because they have additional support at the ends.
4. How do I calculate the deflection of a simply supported or pinned both sides beam?
The deflection of a beam can be calculated using the appropriate deflection formula for the specific beam type. For simply supported beams, the deflection formula is (5WL^4)/(384EI), while for pinned both sides beams, it is (WL^3)/(48EI), where W is the applied load, L is the length of the beam, E is the Young's modulus of the material, and I is the moment of inertia of the beam's cross-sectional area.
5. Can I use the same equations for both simply supported and pinned both sides beams?
No, the equations for simply supported and pinned both sides beams are different and should not be used interchangeably. It is important to use the correct equation for the specific beam type to ensure accurate calculations.
  • General Engineering
  • Mechanical Engineering
9K
  • Other Physics Topics
