Beam Deflection - UDL's and Point Loads
In summary: So, I guess you need to do some more work. Good luck!In summary, the problem involves finding the maximum deflection of a beam with a cross section of 20mm by 10mm and a length of 800mm. The formula for EI is calculated to be 477999.52 N/mm^2 using the cross-section and material properties. Various equations, such as (WI^3)/48EI and (5wI^4)/384EI, have been attempted to calculate the point load and udl's, but there may be a slight underestimate due to the formula being for a udl across the whole beam. Integration may be necessary to accurately calculate the deflection due to the udl's. The
Corsan
Hello,
I have tried for numerous hours to solve this and I'm getting no where, could one of you put me out of my misery?
[PLAIN]http://img98.imageshack.us/img98/3240/beamloads.jpg
The cross section of the beam is 20mm tall by 10 deep. 800mm length.
Hopefully you can see the above image which is the question.
Using the cross-section above I have calculated EI to be
I= bd^3 = 10 x (20^3) = 6666.66
...12...12
Sorry about the dots, spaces didnt seem to work.
Multiply this by E (71.7GPa - aluminium 7075 series) to give 477999.52 N/mm^2.
After this I have tried various equations such as (WI^3)/48EI to calculate the point load.
Also using (5wI^4)/384EI to calculate the UDL's but I am getting silly figures in the thousands.
Is it not a case of finding the answers to these deflection formulas, adding them together and that is the resultant maximum deflection?
However, I have also read through my notes and found something about slopes etc and that has totally thrown me.
Can anyone offer any help?
Many thanks for any assistance.
"(WI^3)/48EI to calculate the point load" has a typo in the bracket. I should be L. That will give you the deflection due to the point load.
If you use (5wI^4)/384EI - with L replacing I in the bracket, as before - you will have a slight underestimate of the deflection because the formula is for a udl across the whole of the beam. There is a formula for the case you have, but I suspect you are expected to do an integration exercise. Is that right?
Hello, thanks for your response, you are correct about the type - bad eyes!
You are right about the integration although a formula would be nice, how would you advise dealing with the UDL situation?
I believe one method would be to assume it is over the length of the beam and then create a virtual UDL to cancel the areas that aren't under load (Macauleys method?)
Thanks again
The central deflection due to the udl sections is given in the Steel designers manual as Wa(3L^2-2a^2)/(96EI), where a=300 in this case, L=800, and you could use this to check your integration. You can use Macaulay if you like, but personally I find it unnecessarily tedious, error prone and academic. No practising engineer uses it. I do agree you find the deflection due the udl's, and the point load separately, and then add them together. That is the application of the principle of superposition for linear systems.
Hello, I am a scientist and I would be happy to assist you with your problem. It seems like you have been working hard on this and I understand your frustration. First, I would like to clarify that the equations you have mentioned are correct for calculating the deflection caused by UDL's and point loads on a beam. However, it is important to make sure that you are using the correct units for your calculations. In this case, the cross-section of the beam is given in millimeters, so all of your calculations should be done in millimeters as well. This could be the reason for your "silly" figures in the thousands.
Also, for the point load, you need to make sure that the distance from the support to the point load is taken into account in your calculation. This distance is given as 200mm in the question.
As for the slopes, they are related to the deflection of the beam and can be calculated using the equations you have mentioned. However, they are not necessary for finding the maximum deflection. You can simply add the deflections caused by the UDL and point load to get the total deflection at the center of the beam.
I hope this helps and if you still have trouble, please let me know and I would be happy to assist you further. Good luck!
Related to Beam Deflection - UDL's and Point Loads
1. What is beam deflection?
Beam deflection is the degree to which a beam bends or curves under a load or force exerted on it. It is a measure of how much the beam will deform under stress.
2. What is a UDL (uniformly distributed load)?
A UDL, or uniformly distributed load, is a load that is evenly distributed along the length of a beam. This type of load can be represented by a constant load per unit length, such as pounds per inch or newtons per meter.
3. What is a point load?
A point load is a single, concentrated force applied to a specific point on a beam. This type of load can be represented by a single force vector, such as pounds or newtons.
4. How do UDL's and point loads affect beam deflection?
UDL's and point loads both cause a beam to deflect, or bend, in different ways. UDL's create a constant bending moment along the length of the beam, resulting in a gradual curve. Point loads, on the other hand, create a concentrated bending moment at a specific point, causing a sharp bend or deflection at that point.
5. What factors affect beam deflection from UDL's and point loads?
The amount of beam deflection from UDL's and point loads is affected by several factors, including the magnitude and location of the load, the length and material of the beam, and the type of support at the ends of the beam. Other factors such as temperature and moisture can also affect beam deflection.
  • Mechanical Engineering
11K
