Yash
- 1
The bearing of B from A is 120 degrees. What is the bearing of A from B?
Yash said:The bearing of B from A is 120 degrees. What is the bearing of A from B?
The bearing of A from B: 120 degrees refers to the direction or angle at which point A is located from point B, measured in a clockwise direction from the north.
The bearing of A from B: 120 degrees is calculated by drawing a line from point B to point A and measuring the angle formed between this line and the north, in a clockwise direction.
The range of values for the bearing of A from B: 120 degrees is 0 to 360 degrees. This means that the bearing can be expressed as 120 degrees, 480 degrees, or any other value that is a multiple of 360 degrees.
The bearing of A from B: 120 degrees is the opposite of the bearing of B from A. This means that the bearing of B from A would be 300 degrees, as it is measured in a clockwise direction from the north.
The bearing of A from B: 120 degrees is important in navigation and surveying, as it helps determine the direction and location of objects in relation to each other. It can also be used to calculate the distance between two points and to plot a course of travel.
