Can You Accurately Compare Bearing Slow Down Functions?
  • Thread starter Kristian311
  • Tags
    #physics
In summary, the article explores the challenges and methodologies involved in accurately comparing the slow down functions of bearings. It emphasizes the importance of standardizing testing conditions and metrics to ensure reliable results. The discussion includes various factors that influence bearing performance, such as material properties, lubrication, and environmental conditions, and suggests best practices for conducting comparative analyses to achieve valid and meaningful outcomes.
Kristian311
So, I have a 2 lists of values, first one has bearing rotations in hz, the other one has the times that the measurement was taken. I have a list of good bearing values.
I have to:
1. Make a way to calculate if the bearing is good based on it's own values compared to the values of the good one.
Also the problem is that the good one starts at 50hz and ends at 0 ant the bearings that are going to be tested are going to start at random different values from 40 to 60 hz.
The rotors are the same at all bearings
What approach should I make?
No Idea
I thought that I can get a function that is representing the values and compare it to the function of the sample bearing, is this right? or is there and easier approach?
Welcome to PF.
I would start by plotting the values to see if there is an exponential decay or some other decay function. That would help me to figure out what kind of function to fit to the data, and that would help me to start to see how to differentiate between good and bad bearing sets.
Can you try that and upload some screenshots of your plots? Use the "Attach files" link below the Edit window to attach your plots to your post.
EDIT/ADD -- Do you know how to plot the data using Excel?
Likes MatinSAR
OK, so the bad bearings start at different values. Do they all end at 0 Hz? If so, isn't it true that a bad bearing starting at, say 40 Hz will take less time to reach 0 Hz than the good bearing over the same 40 to 0 Hz interval?
I would suspect that bad bearings have more friction than good ones. If I were doing this analysis, I would plot the data as @berkeman suggested and use a spreadsheet to fit a polynomial of order 2 or 3. Then I would look at the coefficient of the linear term which is the first derivative of the angular speed, i.e. the acceleration. It should be negative. The larger the magnitude of that coefficient, the worse the bearing. This method does not care at what speed the bearing starts because that's the constant term in the polynomial fit.
It might help to have a model for the "badness" in a bearing along with the model for "goodness".
A bearing that catches and comes to a sudden stop would be bad. Maybe there is grit, a broken ball or some foreign object.
A bearing that decellerates rapidly through some ranges of rotation rate would be bad. Maybe there is a "howl" or "chatter" [loose tolerances means that the shaft is not rotating smoothly, but is spiralling or chattering within its raceway].
A bearing that slows too rapidly would be bad. Maybe it was over-tightened or lacks lubrication.
Even a bearing that slows too slowly could be bad. Maybe it was under-tightened.
Likes berkeman
What do you mean you have a list of good bearing values? If its from a manufacturer, then just know that they controlled/measured the loading during the testing. If you are not doing the same (assuming you are in industry - where loads are "best guesses") I wouldn't expect a 1:1 comparison can be made.
FAQ: Can You Accurately Compare Bearing Slow Down Functions?
What is a bearing slow down function?
A bearing slow down function describes how the rotational speed of a bearing decreases over time due to factors like friction, load, and lubrication conditions. It is a mathematical model used to predict the performance and lifespan of bearings under various operating conditions.
Why is it important to compare bearing slow down functions accurately?
Accurately comparing bearing slow down functions is crucial for selecting the right bearing for specific applications, optimizing maintenance schedules, and ensuring the reliability and efficiency of mechanical systems. It helps in understanding how different bearings will perform under similar conditions, thus aiding in better decision-making.
What factors influence the accuracy of bearing slow down function comparisons?
The accuracy of comparing bearing slow down functions can be influenced by several factors, including the quality of the input data (such as load, speed, and lubrication conditions), the precision of the mathematical models used, the consistency of testing conditions, and the expertise of the analysts performing the comparisons.
How can you improve the accuracy of bearing slow down function comparisons?
To improve the accuracy, ensure high-quality and consistent input data, use advanced and validated mathematical models, perform controlled and repeatable tests, and leverage the expertise of experienced engineers and scientists. Additionally, using advanced simulation tools and conducting real-world validation can further enhance accuracy.
Are there any standardized methods for comparing bearing slow down functions?
While there may not be a single standardized method universally accepted, several industry standards and guidelines exist that outline best practices for testing and analyzing bearing performance. Organizations like ISO and ASTM provide standards that can help ensure consistency and reliability in bearing slow down function comparisons.
