Beginner's Verifying Trig Identity
In summary, the conversation discussed the relationship between cotangent and sine, as well as the process of converting sine into a fraction. The correct answer for the problem is tan θ = sin θ/cos θ.
courtbits
\(\displaystyle (\cot \theta)(\sin \theta)\)
So far I understand that you can make
\(\displaystyle (\cot a) \implies (\frac{\cos \theta}{\sin \theta})\)
Then it would come to
\(\displaystyle (\frac{\cos \theta}{\sin \theta})(\sin \theta)\)
I'm stuck at when making \(\displaystyle (\sin \theta)\) into a fraction.
The sine in between the asterisks is what I mean:
\(\displaystyle (\frac{\cos \theta}{\sin \theta}) *(\sin \theta)*\)
I have no idea if the fraction needs to be:
\(\displaystyle (\frac{1}{\sin \theta})\)
OR
\(\displaystyle (\frac{\sin \theta}{1})\)
I know it's silly to ask over, but also how to proceed the problem.
The answer choices are ~
a.) \(\displaystyle \tan \theta\)
b.) \(\displaystyle \cos \theta\)
I would really like to know which answer it is, and the reason behind it.
*Thanks in advance!
Mathematics news on Phys.org
\(\displaystyle (\cot a) \implies (\frac{\sin \theta}{\cos \theta})\)
No
\(\displaystyle \cot \theta = (\frac{\cos \theta}{\sin \theta})\)
kaliprasad said:
No
Wow. x.x A typo error. I will fix it. XD
now you are right till this point then the mistake
Would it be \(\displaystyle (\frac{\cos \theta}{\sin \theta})(\frac{\sin \theta}{1})\)?
yes but 1 in denominator is unnecessary and result becomes
Oh OH! I got it! Now I understand! XD Thank you very much!
tan θ = sin θ/cos θ
FAQ: Beginner's Verifying Trig Identity
What is a trigonometric identity?
A trigonometric identity is an equation that relates different trigonometric functions. It is used to simplify and solve equations involving trigonometric functions.
How do you verify a trigonometric identity?
To verify a trigonometric identity, you need to manipulate the given equation using basic trigonometric identities and algebraic manipulation to show that the left side of the equation is equal to the right side.
What are some common trigonometric identities?
Some common trigonometric identities include the Pythagorean identities, sum and difference identities, double angle identities, and half angle identities.
Why is it important to verify trigonometric identities?
Verifying trigonometric identities is important because it helps to ensure the accuracy of mathematical calculations involving trigonometric functions. It also allows for the simplification and manipulation of equations, making them easier to solve.
What are some tips for verifying trigonometric identities?
Some tips for verifying trigonometric identities include starting with the more complex side of the equation, using basic trigonometric identities, and working step by step with clear and organized calculations.
