Beginning of accelerating expansion
In summary, the conversation is about trying to find the latest estimate for when the universe's expansion began to accelerate after inflation. The estimates vary from 5 to 8 billion years ago, but there is no consensus on a specific time range. The latest observational evidence is used to support these estimates, and the parameters used in the model, such as Hubble constant and cosmological constant, can affect the results. Using a calculator, one can see that the acceleration began around 7 billion years ago, but this inflection point can be changed by adjusting the model parameters.
hendoS
I've been trying to find the latest, best guess, as to how long ago the universe's expansion began to accelerate (post-inflation). I've seen various estimates on websites from 5 billion to 8 billion years ago.
Is there any kind of consensus in the community that studies these things as to a more limited time range for this acceleration to have started? What is the latest observational evidence used to support these estimates?
Any links and additional info is appreciated!
Space news on Phys.org
I don't know the answer but am curious as to why it matters to you.
It depends on what parameters you plug into the model, mainly on H0, and Lambda. You can go get your favorite parameters, e.g. the Planck report gives you a choice of whether they depend on just Planck data or a mix of theirs with various other studies.
Once you decide on the two parameters you can plug them into some version (like Jorrie's calculator) of the standard LCDM cosmic model and it will tell you. I will work an example for you. Suppose you want to use Jorrie's DEFAULT parameters which he essentially got from 2013 Planck mission report.
Then it is very simple. You click on the Lightcone link (in my sig) and you narrow the time range say make Supper = 3 and Slower=1 (which is the present, or z=0)
and you might want to increase the number of steps N = 20 (and later even higher for better resolution, but let's start with 20)
and then you go to column select menu and check the "R0a'(t)" which gives you the TIME DERIVATIVE OF A REPRESENTATIVE DISTANCE.
And then you press "calculate" and you will get among other things the growth speed of a sample distance and it will INITIALLY DECLINE and then around say year 7 billion it will BEGIN TO INCREASE. And that's your answer.
I did exactly what I suggested you do and got this:
[tex]{\scriptsize\begin{array}{|c|c|c|c|c|c|}\hline R_{0} (Gly) & R_{\infty} (Gly) & S_{eq} & H_{0} & \Omega_\Lambda & \Omega_m\\ \hline 14.4&17.3&3400&67.9&0.693&0.307\\ \hline \end{array}}[/tex] [tex]{\scriptsize\begin{array}{|r|r|r|r|r|r|r|r|r|r|r|r|r|r|r|r|} \hline a=1/S&S&T (Gy)&R (Gly)&D_{now} (Gly)&D_{then}(Gly)&D_{hor}(Gly)&a'R_{0} (c) \\ \hline 0.333&3.000&3.2851&4.8024&17.294&5.765&11.260&0.9995\\ \hline 0.352&2.840&3.5592&5.1793&16.494&5.809&11.615&0.9791\\ \hline 0.372&2.688&3.8546&5.5797&15.679&5.833&11.967&0.9602\\ \hline 0.393&2.544&4.1726&6.0033&14.847&5.836&12.316&0.9428\\ \hline 0.415&2.408&4.5145&6.4498&14.001&5.814&12.660&0.9271\\ \hline 0.439&2.280&4.8815&6.9183&13.141&5.765&12.998&0.9131\\ \hline 0.463&2.158&5.2749&7.4072&12.269&5.686&13.327&0.9010\\ \hline 0.490&2.042&5.6956&7.9146&11.386&5.575&13.647&0.8909\\ \hline 0.517&1.933&6.1448&8.4377&10.494&5.428&13.957&0.8828\\ \hline 0.546&1.830&6.6229&8.9733&9.594&5.243&14.253&0.8770\\ \hline 0.577&1.732&7.1307&9.5174&8.691&5.017&14.536&0.8735\\ \hline 0.610&1.639&7.6686&10.0656&7.784&4.748&14.804&0.8726\\ \hline 0.644&1.552&8.2365&10.6131&6.879&4.432&15.057&0.8743\\ \hline 0.681&1.469&8.8344&11.1548&5.976&4.068&15.292&0.8788\\ \hline 0.719&1.390&9.4618&11.6855&5.079&3.653&15.511&0.8863\\ \hline 0.760&1.316&10.1179&12.2004&4.192&3.185&15.713&0.8968\\ \hline 0.803&1.246&10.8017&12.6948&3.316&2.662&15.897&0.9106\\ \hline 0.848&1.179&11.5121&13.1648&2.456&2.082&16.065&0.9276\\ \hline 0.896&1.116&12.2475&13.6072&1.612&1.444&16.216&0.9482\\ \hline 0.947&1.056&13.0065&14.0193&0.788&0.746&16.351&0.9723\\ \hline 1.000&1.000&13.7872&14.3999&0.000&0.000&16.472&1.0000\\ \hline \end{array}}[/tex]
The growth speed for this sample distance is given in units of the speed of light. You can see that it gets as low as 0.8726 c. You can see the inflection point is around year 7.67 billion. You can make the inflection point change by choosing a slightly different H0 Hubble rate. The way you control that is by controlling its reciprocal the Hubble distance R0 = c/H0
The default Hubble distance is 14.4 billion LY as you an see at the top. You can type in a slightly different R0 and that will change H0 and that will change the numbers that the model computes, including the inflection point.
It is important for you to find the "column definition and selection" menu so that you can select "a'(t) R0" the distance growth speed of a sample distance. You can also UNselect various columns so the output table will not be so wide and distracting. When I did it I unchecked a couple of source recession velocity columns Vnow and Vthen because they are not relevant to your question and might be distracting.
One other thing I did, forgot to tell you, was when I opened "column definition and selection" menu to check the distance growth speed a'R0 at that point I also BUMPED UP THE NUMBER OF DECIMAL PLACES in that column from 2 to 4, so we could see the result in 4 decimal precision.
If you go to that menu you can see how the precision of each column can be varied as you wish.
I wanted to see how changing the model parameters would move the inflection point so I made R0 less (14.0 billion LY) which makes H0 slightly larger as you can see if you try it. And that then made the inflection come slightly EARLIER. Closer to 7.6 than to 7.7.
If you are familiar with the cosmological constant Lambda you know that it determines the longterm value of the Hubble radius namely Rinfinity, which viceversa determines Lambda by a simple formula. So you can try varying that too. I suppose increasing Lambda means decreasing Rinfinity (increasing the longterm growth rate H(t)) and probably makes the inflection come EARLIER, i.e. acceleration starts earlier if you reduce the Rinfinity parameter, you can try that with the calculator if you want.
I can provide some insights on the beginning of accelerating expansion in the universe. The current understanding is that the universe underwent a period of rapid expansion known as inflation in its early stages. This was followed by a period of decelerating expansion for several billion years until around 5-8 billion years ago, when the expansion began to accelerate again.
There is currently a consensus within the scientific community that the acceleration of the universe's expansion began around 5-8 billion years ago. This is based on a combination of observational evidence and theoretical models. One of the key pieces of evidence is the observation of distant supernovae, which showed that the expansion of the universe is actually accelerating rather than slowing down as expected. This was a groundbreaking discovery that led to the 2011 Nobel Prize in Physics.
Other observational evidence includes the cosmic microwave background radiation, which provides a snapshot of the early universe and supports the idea of inflation. Additionally, the distribution of galaxies and the large-scale structure of the universe also support the concept of accelerating expansion.
It is important to note that these estimates and evidence are constantly being refined and updated as new observations and data become available. Therefore, it is possible that there may be some variation in the estimates you have seen on different websites.
If you are interested in learning more about this topic, I recommend checking out resources from reputable sources such as NASA, the European Space Agency, and scientific journals. These sources provide up-to-date information and explanations on the latest research and evidence supporting the beginning of accelerating expansion in the universe.
Related to Beginning of accelerating expansion
1. What is the "beginning of accelerating expansion" in relation to the universe?
The beginning of accelerating expansion refers to a period in the history of the universe where the rate of expansion was increasing, rather than slowing down. This phenomenon is also known as cosmic inflation and is thought to have occurred approximately 13.8 billion years ago.
2. What caused the beginning of accelerating expansion?
The exact cause of the beginning of accelerating expansion is still a subject of debate among scientists. However, one theory suggests that a mysterious force known as dark energy, which makes up a large percentage of the universe, is responsible for this phenomenon.
3. How was the beginning of accelerating expansion discovered?
The beginning of accelerating expansion was first hypothesized by physicist Alexander Friedmann in the 1920s. It was later confirmed in the late 1990s through observations of distant supernovae, which showed that the expansion of the universe was accelerating rather than slowing down.
4. How does the beginning of accelerating expansion impact our understanding of the universe?
The beginning of accelerating expansion has significant implications for our understanding of the universe. It suggests that the expansion of the universe is not only continuing, but also accelerating, which has led scientists to conclude that the universe will continue to expand indefinitely rather than collapsing in on itself.
5. Are there any ongoing studies or research related to the beginning of accelerating expansion?
Yes, there are ongoing studies and research related to the beginning of accelerating expansion. Scientists are still trying to understand the exact cause of this phenomenon and the role of dark energy in the expansion of the universe. Additionally, ongoing observations and experiments are being conducted to further our understanding of this topic.
  • Cosmology
