I Behavior of a curved 2D sheet and a curved 1D wire under acoustic wave
The discussion focuses on the behavior of stiff wires and surfaces when excited by multiple acoustic waves of varying frequencies. It highlights the complexity of analyzing such systems, suggesting that Frequency Response analysis using Finite Element Method (FEM) is appropriate. References to Timoshenko's "Theory of Plates & Shells" and general FEM theory are recommended for further study. The importance of acoustic impedance and boundary conditions in modeling complex shapes is emphasized. The conversation concludes with the participant feeling informed on how to proceed with their research.
Seanskahn
TL;DR Summary
How do complex shapes respond to acoustic waves?
Good day.
We know how simple objects, such as 1D wires behave when a simple harmonic wave travels along a wire, or two wires knotted togethe.We also know what happens if you excite a circular thin disc with a single frequency.
Are there some material I can read on, that considers the effect of exciting a stiff wire given by y = f(x) , for a polynomial or exponential function f, excited by an acoustic wave comprising of multiple frequencies?
While we are at it how does a surface given by z = f(x,y) respond if several acoustic waves are falling on it, each at a different point, each comprising of multiple frequencies?
I understand that an analytical solution would be very complicated.
I am not requesting you to solve it for me, I just want you to direct my to some study / research material in this direction.
Thank you.
Sounds like you want to do a Frequency Response analysis using FEM. A surface can probably best be modeled by shell elements, so Timoshenko's canonical 'Theory of Plates & Shells' might be a good reference.
You can also model wires with FEM. So any reference on FEM theory, numerical analysis and theory of elasticity would help I guess. There are tons of books about that.
Welcome to PF.
Complex shapes respond in complex ways.
The acoustic impedance and the degree of freedom at boundaries or attachment points will be important. You have no choice but to use FEM, or to build and test a model.
Baluncore said:
Welcome to PF.
Thank you for your answer.
I know how to proceed now.
Enjoy your weekend.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
