Behavior of a graph at a point
In summary, the behavior of the function y = cubicroot(x + 2) at x = -2 is a vertical tangent. This means that the derivative of the function does not exist at this point, but the limits of the derivatives from above and below exist and are different. It is not a cusp or a corner. Therefore, the correct answer is (D) vertical tangent.
Jacobpm64
239
Which of the following describes the behavior of y = cubicroot(x + 2) at x = -2
(A) differentiable
(B) corner
(C) cusp
(E) discontinuity
well i graphed the function, and I'm not sure.. i know for sure it isn't E... because f(-2) = 0... it has a value.. uhmm.. as for the rest I'm not sure.. i don't even know what a corner and a cusp is.
Well, a cusp is when the second derivative of the function (which measures curvature) decreases or increases on both sides, making an upside down v or right-side up v.
A corner can be described if f is not differential at any point where the secant lines have different limits as they approach a point (it looks like a corner). So can vertical tangency (if point looks like it's derivative would be vertical).
If I were you I would look at what it cannot be.
as for corner.. that just completely and utterly confuses me ;\
let's see..
so, hmm... we know it isn'tA, we aren't sure about B, we know it can't be C, we know it is D, and we know it can't be E..
So we're left with Discussions about B..
am i correct thus far?
A "corner" occurs when the derivative does not exit- but the limits of the derivatives from above and below exist but are different. A "cusp" occurs when the two one sided limits of the derivative do not exist.
so it's none of those... and the answer is only a vertical tangent
FAQ: Behavior of a graph at a point
What is the behavior of a graph at a point?
The behavior of a graph at a point refers to the trend or pattern that the graph exhibits at a specific point or value. It can include characteristics such as the slope, concavity, and continuity of the graph at that point.
How do you determine the behavior of a graph at a point?
The behavior of a graph at a point can be determined by analyzing the graph's derivative at that point. The derivative provides information about the slope and concavity of the graph, which can help determine its behavior.
What does a positive/negative slope at a point indicate about the graph's behavior?
A positive slope at a point indicates that the graph is increasing at that point, while a negative slope indicates that the graph is decreasing at that point. This can also give insight into the overall trend of the graph.
How does the continuity of a graph at a point affect its behavior?
The continuity of a graph at a point refers to whether the graph is connected or has any breaks or gaps at that point. A continuous graph will have a smooth and consistent behavior, while a discontinuous graph may have sudden changes or jumps in behavior at that point.
Can the behavior of a graph at a point change?
Yes, the behavior of a graph at a point can change depending on the function or equation being graphed. For example, a graph may have a positive slope at one point and a negative slope at another point. It is important to consider the entire graph and its characteristics when determining the behavior at a specific point.
