MHB Belinda Obeng's question at Yahoo Answers regarding a solid of revolution
  • Thread starter Thread starter MarkFL
    Revolution Solid
The discussion focuses on calculating the volume of the solid formed by revolving the region bounded by the curves y=x^2 and y^2=8x around the y-axis. The points of intersection are determined to be (0,0) and (2,4). Two methods are used for volume calculation: the washer method and the shell method, both yielding a final volume of 24π/5. The washer method involves integrating the difference of the outer and inner radii, while the shell method uses cylindrical shells for integration. The calculations confirm the consistency of results from both methods.
MarkFL
MHB
Here is the question:
The volume of the solid generated by revolving the region bounded by the graph y=x^2,y^2=8x,about the y-axis?
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Belinda Obeng,
First, let's determine the points of intersection for the two curves. Substituting for $y$ as given in the first equation into the second, we obtain:
$$\left(x^2 \right)^2=8x$$
$$x^4-8x=0$$
$$x\left(x^3-2^3 \right)=0$$
$$x(x-2)\left(x^2+2x+2^2 \right)=0$$
The quadratic factor has complex roots, hence we find:
$$x=0,\,2$$
Thus, the two points of intersection are:
$$(0,0),\,(2,4)$$
To use the washer method, we find the volume of an arbitrary washer is:
$$dV=\pi\left(R^2-r^2 \right)\,dy$$
where:
$$R^2=y$$
$$r^2=\frac{y^4}{64}$$
Hence:
$$dV=\pi\left(y-\frac{y^4}{64} \right)\,dy$$
Adding the volume elements by integrating, we find:
$$V=\pi\int_0^4 y-\frac{y^4}{64}\,dy$$
Applying the FTOC, we obtain:
$$V=\pi\left[\frac{y^2}{2}-\frac{y^5}{320} \right]_0^4=\frac{24\pi}{5}$$
Using the shell method, we find the volume of an arbitrary shell is:
$$dV=2\pi rh\,dx$$
where:
$$r=x$$
$$h=\sqrt{8x}-x^2$$
Hence:
$$dV=2\pi x\left(\sqrt{8x}-x^2 \right)\,dx=2\pi\left(2\sqrt{2}x^{\frac{3}{2}}-x^3 \right)\,dx$$
Summing the volume elements by integrating, we find:
$$V=2\pi\int_0^2 2\sqrt{2}x^{\frac{3}{2}}-x^3\,dx$$
Applying the FTOC, we find:
$$V=2\pi\left[\frac{4\sqrt{2}}{5}x^{\frac{5}{2}}-\frac{x^4}{4} \right]_0^2=2\pi\left(\frac{32}{5}-4 \right)=\frac{24\pi}{5}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
