- #36
- 8,173
- 1,903
Caroline Thompson said:1. I trust your follow-up will cover the QM prediction for cases in which the assumed distribution of [tex]\lambda[/tex] is not uniform.
2. The classical optics formula (i.e. the LR formula) is readily adapted, but can the QM one compete?
1. Why would I do that? The QM prediction does not need a [tex]\lambda[/tex]. This is only present in LR.
2. As to your formula being the classical one... if it is the classical one, why is it at variance with Malus' Law?
The point is that Caroline's formula (1) is a late introduced formula which is essentially pulled from thin air, and can hardly be called classical in the normal sense of the term. And I would be very surprised to see an experiment demonstrate deviation from rotational invariance. Show me some significant references to these ideas prior to 1965.
Please note that EPR assumed rotational invariance, and also assumed that there was an angle at which there would be perfect correlation - something which does not occur at ANY angle with Caroline's formula (1).
