JohnM24018
- 15
- 1
I would like to disconnect the secondary windings from a stereo preamp to test the voltages of the secondary windings. The transformer has a 330 - 0 - 330 volt center tapped secondary and a 10.9 volt secondary. It is to be used with house current - 110 or so in Virginia. I have measured the current from the plug. It is OK.
My intent is to use a digital multi meter to measure the voltages of the secondary windings. I intended to measure the 330 leg to zero then zero to the other 330. I was going to test the other windings in the same way.
Is there a better way to do that? If so what is it? Should it be loaded - what ever that is.
The reason I feel this needs to be done is that after some work to the unit all 4 of the 12AX7 tube's pins (#1 and 6) (4 tubes, pins 1 and 6 on each) are currently measuring over 450 volts. They normally measure 115 and 135 volts DC. I tried two meters and got the same results. I see no burns and saw no smoke or sparks. The unit is around 60 years old but has been working recently. I have rechecked my work and am satisfied.
I possesses the sheet from the distributor and could upload it if requested. Some sites prefer me not.
