Benefits of Lagrangian mechanics with generalised coordinates
In summary, Lagrangian mechanics has the advantage of working in any frame of reference, unlike Newtonian mechanics which only works in an inertial frame. However, this comes at the cost of a more complicated form for the Lagrangian. Additionally, the Lagrangian method allows for the solving of problems without worrying about unknown holonomic constraint forces. While Newton's second law can also be transformed to work in a non-inertial frame, it requires additional considerations about derivatives and results in three correction terms that can be viewed as forces. The Lagrangian approach, on the other hand, can be easily transformed to a non-inertial frame and still produce the same equations of motion without the need for additional corrections.
lriuui0x0
101
25
I have sometimes seen the claim that one advantage of Lagrangian mechanics is that it works in any frame of reference, instead of like Newtonian mechanics which will hold only in the inertial frame of reference. However isn't this gain only at the sacrifice that the Lagrangian will need to take a more complicated form? If this can be considered as frame independent, we can also claim that Newton's second law ##F = ma## works in any frame of reference, if we allow the force to take a more complicated form, i.e. with the addition of the fictitious forces.
Just want to double check that if this reasoning is correct and is there any more fundamental advantages of Lagrangian mechanics in this regard, or is this just that the Lagrangian being a scalar making the coordinate transformation easier than force vectors?
That is one aspect, yes. That a particular trajectory is an extremal of the action functional does not depend on the coordinates, and indeed you should try to show that if the Euler-Lagrange equation is satisfied in coordinates ##q^i## then it is also satisfied in coordinates ##\tilde{q}^i = \tilde{q}^i(q^1, \dots, q^n, t)##.
There are other reasons! Importantly, the Lagrangian method allows you to solve problems without worrying about the unknown holonomic constraint forces (such as the contact force that a hoop exerts on a bead, etc.).
ergospherical said:
That is one aspect, yes. That a particular trajectory is an extremal of the action functional does not depend on the coordinates, and indeed you should try to show that if the Euler-Lagrange equation is satisfied in coordinates qi then it is also satisfied in coordinates q~i=q~i(q1,…,qn,t).
About this particular benefit, can't we say that Newton's second law is on the same footing here? Because we can also transform the coordinates to get Newton's equation of motion into a non-inertial frame? Similar to transforming coordinates for the Lagrangian?
Sort of, but not really. In it's original form, Newton ##\mathrm{II}## holds only in an inertial frame, ##m\boldsymbol{a}_{\mathrm{in}} = \boldsymbol{F}##. To transform this equation to a non-inertial frame requires some facts about the derivatives of vectors with respect to different frames.
Viz, given a frame ##S = Oxyz##, the derivative of a vector ##\boldsymbol{u}(t) = u^x(t) \boldsymbol{e}_x + u^y(t) \boldsymbol{e}_y + u^z(t) \boldsymbol{e}_z## with respect to time is defined as\begin{align*}\dfrac{d\boldsymbol{u}}{dt} \bigg{|}_S = \dfrac{du^x}{dt}(t) \boldsymbol{e}_x + \dfrac{du^y}{dt}(t) \boldsymbol{e}_y + \dfrac{du^z}{dt}(t) \boldsymbol{e}_z\end{align*}Given a different frame ##S' = O'x'y'z'##, rotating at angular velocity ##\boldsymbol{\omega}## with respect to ##S##, one can prove that\begin{align*}\dfrac{d\boldsymbol{u}}{dt} \bigg{|}_{S} = \dfrac{d\boldsymbol{u}}{dt} \bigg{|}_{S'} + \boldsymbol{\omega} \times \boldsymbol{u}\end{align*}Let ##S## be the inertial frame and ##S'## be the non-inertial frame. For simplicity, assume that the origins coincide at all times. Then \begin{align*}\boldsymbol{a}_{\mathrm{in}} &= \dfrac{d^2 \boldsymbol{r}}{dt^2} \bigg{|}_S \\&= \dfrac{d}{dt} \bigg{|}_S \left(\dfrac{d\boldsymbol{r}}{dt} \bigg{|}_{S'} + \boldsymbol{\omega} \times \boldsymbol{r} \right) \\&= \dfrac{d^2 \boldsymbol{r}}{dt^2} \bigg{|}_{S'} + \boldsymbol{\omega} \times \dfrac{d\boldsymbol{r}}{dt} \bigg{|}_{S'} + \dfrac{d}{dt} \bigg{|}_S \left( \boldsymbol{\omega} \times \boldsymbol{r} \right)\end{align*}The last term is\begin{align*}\dfrac{d}{dt} \bigg{|}_S \left( \boldsymbol{\omega} \times \boldsymbol{r} \right) &= \dfrac{d\boldsymbol{\omega}}{dt} \bigg{|}_S \times \boldsymbol{r} + \boldsymbol{\omega} \times \dfrac{d\boldsymbol{r}}{dt} \bigg{|}_S \\&= \boldsymbol{\alpha} \times \boldsymbol{r} + \boldsymbol{\omega} \times \left( \dfrac{d\boldsymbol{r}}{dt} \bigg{|}_{S'} + \boldsymbol{\omega} \times \boldsymbol{r} \right) \\&= \boldsymbol{\alpha} \times \boldsymbol{r} + \boldsymbol{\omega} \times \dfrac{d\boldsymbol{r}}{dt} \bigg{|}_{S'} + \boldsymbol{\omega} \times (\boldsymbol{\omega} \times \boldsymbol{r})\end{align*}To simplify the notation, one calls ##\boldsymbol{a}' \equiv \dfrac{d^2 \boldsymbol{r}}{dt^2} \bigg{|}_{S'}## the acceleration relative to ##S'## and ##\boldsymbol{v'} \equiv \dfrac{d\boldsymbol{r}}{dt} \bigg{|}_{S'}## the velocity relative to ##S'##. You have\begin{align*}\boldsymbol{a}_{\mathrm{in}}= \boldsymbol{a}' + 2\boldsymbol{\omega} \times \boldsymbol{v}' +\boldsymbol{\omega} \times (\boldsymbol{\omega} \times \boldsymbol{r}) + \boldsymbol{\alpha} \times \boldsymbol{r}\end{align*}Newton ##\mathrm{II}## is transformed to\begin{align*}m \boldsymbol{a}' = \boldsymbol{F} -2m\boldsymbol{\omega} \times \boldsymbol{v}' -m \boldsymbol{\omega} \times (\boldsymbol{\omega} \times \boldsymbol{r}) -m \boldsymbol{\alpha} \times \boldsymbol{r}\end{align*}Heuristically, the three correction terms on the right hand side can be viewed as forces.
On the other hand, try starting with a general Lagrangian ##L = \dfrac{1}{2}m \dot{\boldsymbol{r}}^2 - V(\boldsymbol{r})## in an inertial frame. Then transform this Lagrangian to a non-inertial frame by means of a coordinate transformation, using the fact that the Lagrangian approach is valid in any coordinates. You'll notice that the correction terms arise, as expected.
Likes lriuui0x0
In addition to what @ergospherical mentioned, one other consideration is that the Lagrangian is a scalar while Newton’s 2nd is a vector equation.
So this means the calculation with scalar is easier?
Yes, by about a factor of 3.
FAQ: Benefits of Lagrangian mechanics with generalised coordinates
What is Lagrangian mechanics with generalised coordinates?
Lagrangian mechanics with generalised coordinates is a mathematical framework used to describe the motion of a system of particles. It is based on the principle of least action, where the motion of a system is determined by minimizing the action, which is a measure of the energy of the system.
What are the benefits of using Lagrangian mechanics with generalised coordinates?
There are several benefits to using Lagrangian mechanics with generalised coordinates. It allows for a more elegant and concise formulation of the equations of motion compared to traditional Newtonian mechanics. It also allows for a more general approach, as it can be applied to systems with any number of particles and any type of constraints.
How does Lagrangian mechanics with generalised coordinates differ from Newtonian mechanics?
In Newtonian mechanics, the motion of a system is described by the forces acting on each particle. In Lagrangian mechanics with generalised coordinates, the motion is described by the Lagrangian function, which takes into account the kinetic and potential energy of the system.
Can Lagrangian mechanics with generalised coordinates be applied to all types of systems?
Yes, Lagrangian mechanics with generalised coordinates can be applied to any type of system, including mechanical, electrical, and even quantum systems. As long as the system can be described by a set of coordinates and has well-defined kinetic and potential energy, Lagrangian mechanics can be used.
Are there any limitations to using Lagrangian mechanics with generalised coordinates?
While Lagrangian mechanics with generalised coordinates is a powerful and versatile tool, it does have some limitations. It may not be as intuitive as Newtonian mechanics for some systems, and it can be more challenging to apply to non-conservative systems. Additionally, it may not be suitable for systems with a large number of particles, as the calculations can become complex.
