Benoulli's Equaiton Pipe Pressure Problem
In summary, the problem involves water flowing down a tapered pipe and the goal is to calculate the pressure difference between the upper and lower ends of the pipe. Using the Bernoulli equation, we can equate the pressure at the top of the pipe with the pressure at the bottom of the pipe, as they both have the same constant. By solving for the unknown pressures, we can determine which end of the pipe has the higher pressure.
mm874
Water flows down a pipe which tapers from 200 mm diameter to 125 mm diameter at the lower end. The difference in height between the two ends of the pipe is 4.0 m and the rate of flow is 1.50 m3 min-1. Calculate the pressure difference between the upper and lower ends of the pipe. Which end has the higher pressure?
P+ρgh+0.5ρv^2=Constant
Volumetric Flow rate = A*v
Mass Flow Rate = ρ*Volumetric Flow rate
Velocity at top = 0.025/0.0314 = 0.796m/s
Velocity at bottom = 0.025/0.0122 = 2.49m/s
Then I get lost at I put all the results into benoulli's equation but am not sure what
to do from there?
Write your Bernoulli equation at the top of the pipe.
Write another Bernoulli equation for the bottom of the pipe.
The two Bernoulli equations equal the same constant, and therefore equal each other.
The only unknowns are the pressures at each end of the pipe.
So how do you calculate the unknowns if there is one either side. The pressure cannot be equal at both ends. As it state the faster the speed the lower the pressure.
You are only asked to find which end of the pipe has the higher pressure. By equating the two Bernoulli equations, you should be able to determine the ratio of the pressures, and depending on the magnitude of the ratio, which is the higher pressure.
As a scientist, it is important to approach problems like this in a systematic and logical manner. Let's break down the problem and use the given information to solve for the pressure difference between the upper and lower ends of the pipe.
First, we can use Bernoulli's equation to relate the pressure at the two ends of the pipe:
P1 + ρgh1 + 0.5ρv1^2 = P2 + ρgh2 + 0.5ρv2^2
Where P1 and P2 are the pressures at the upper and lower ends of the pipe, respectively; ρ is the density of water; g is the acceleration due to gravity; h1 and h2 are the heights of the two ends of the pipe; and v1 and v2 are the velocities at the two ends of the pipe.
Next, we can use the given information to solve for the velocities at the two ends of the pipe. We know that the volumetric flow rate is 1.50 m^3/min, so we can use the equation Volumetric Flow rate = A*v to solve for v1 and v2. The cross-sectional area of the pipe at the top is A1 = π(0.1m)^2 = 0.0314 m^2 and at the bottom is A2 = π(0.0625m)^2 = 0.0122 m^2. Therefore, v1 = 0.796 m/s and v2 = 2.49 m/s.
Now, we can plug these values into Bernoulli's equation:
We know that the difference in height between the two ends of the pipe is 4.0 m, so h2 = 4.0 m and h1 = 0 m. Also, we can assume that the density of water is constant, so we can cancel it out on both sides of the equation. This leaves us with:
P1 + 0 + 0.5v1^2 = P2 + 4.0 + 0.5v2^2
Substituting in our previously calculated values, we get:
P1 + 0 + 0.5(0.796)^2 = P2 +
FAQ: Benoulli's Equaiton Pipe Pressure Problem
What is Bernoulli's equation?
Bernoulli's equation is a fundamental principle in fluid mechanics that describes the relationship between pressure, velocity, and elevation in a flowing fluid. It states that as the velocity of a fluid increases, the pressure decreases, and vice versa.
How is Bernoulli's equation used in pipe pressure problems?
In pipe pressure problems, Bernoulli's equation is used to calculate the pressure at different points along a pipe. By equating the total energy at two points along the pipe (where one point is at a higher elevation and the other is at a lower elevation), the pressure difference between the two points can be determined.
What are the assumptions made in Bernoulli's equation?
Bernoulli's equation assumes that the fluid is incompressible (i.e. its density remains constant), inviscid (i.e. there is no friction), and flows along a streamline (i.e. the flow is steady and no energy is lost due to turbulence).
Can Bernoulli's equation be applied to all types of fluids?
No, Bernoulli's equation is only applicable to ideal fluids, which are non-viscous and incompressible. Real fluids, such as air and water, do not fully adhere to the assumptions made in Bernoulli's equation and therefore, it can only be used as an approximation in certain situations.
What are some practical applications of Bernoulli's equation?
Bernoulli's equation has many practical applications, including predicting the lift force on airplane wings, designing water sprinkler systems, and measuring the flow rate in pipes. It is also used in hydraulics, aerodynamics, and other fields of engineering and science.
