MHB Berk's question via email about approximating change
  • Thread starter Thread starter Prove It
    Change Email
The speed of sound in an ideal fluid is expressed as c = √(γRT), where T is the temperature in Kelvin. A 10% increase in temperature leads to an approximate change in speed, calculated using calculus. The derivative of c with respect to T is found to be d(c)/d(T) = √(γR)/(2√T). With a 10% increase in T, the resulting change in c is approximately c/20, indicating a 5% increase in the speed of sound. This analysis confirms the relationship between temperature changes and sound speed in ideal fluids.
Prove It
MHB
The speed of sound $\displaystyle \begin{align*} c \end{align*}$ in an ideal fluid is related to the temperature $\displaystyle \begin{align*} T \end{align*}$ (measured in $\displaystyle \begin{align*} ^{\circ} K \end{align*}$) by
$\displaystyle \begin{align*} c = \sqrt{\gamma \, R \, T} \end{align*}$
where $\displaystyle \begin{align*} \gamma \end{align*}$ and $\displaystyle \begin{align*} R \end{align*}$ are constants.
Suppose that $\displaystyle \begin{align*} T \end{align*}$ increases by 10% from some base value. Use calculus to determine the approximate percentage change in $\displaystyle \begin{align*} c \end{align*}$, according to the ideal fluid model.
If we remember that the derivative is defined by $\displaystyle \begin{align*} \frac{\mathrm{d}y}{\mathrm{d}x} = \lim_{\Delta\,x \to 0} \frac{y\left( x + \Delta\,x \right) - y\left( x \right)}{\Delta \, x} \end{align*}$ then that means that as long as $\displaystyle \begin{align*} \Delta \,x \end{align*}$ is small, then $\displaystyle \begin{align*} \frac{\mathrm{d}y}{\mathrm{d}x} \approx \frac{\Delta \,y}{\Delta\,x} \end{align*}$.
Thus we can say $\displaystyle \begin{align*} \frac{\mathrm{d}c}{\mathrm{d}T} \approx \frac{\Delta\,c}{\Delta\,T} \end{align*}$ and so $\displaystyle \begin{align*} \Delta\,c \approx \frac{\mathrm{d}c}{\mathrm{d}T}\,\Delta\,T \end{align*}$.
Now from $\displaystyle \begin{align*} c = \sqrt{\gamma\,R\,T} \end{align*}$ we have $\displaystyle \begin{align*} \frac{\mathrm{d}c}{\mathrm{d}T} = \frac{\sqrt{\gamma\,R}}{2\,\sqrt{T}} \end{align*}$, and so with a 10\% increase in T, that means $\displaystyle \begin{align*} \Delta\,T = \frac{T}{10} \end{align*}$, thus
$\displaystyle \begin{align*} \Delta\,c &\approx \frac{\sqrt{\gamma\,R}}{2\,\sqrt{T}}\cdot \frac{T}{10} \\ &= \frac{\sqrt{\gamma\,R\,T}}{20} \\ &= \frac{c}{20} \end{align*}$
So that means that the change in c is $\displaystyle \begin{align*} \frac{1}{20} \end{align*}$ of the original c, so a 5% increase.
Mathematics news on Phys.org
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
11K
10K
10K
11K
