Berman's zero energy condition for universe
In summary, the conversation discusses the presence of a cosmological constant and its effect on the energy density of the universe in the context of quantum gravity. There is a disagreement on whether the energy of dark energy should be considered in the calculation, and whether GR and QM have different views on the concept of "nothing". Ultimately, it is concluded that while their conceptual approaches may differ, they are physically equivalent.
twofish-quant
6,821
I've been looking over the quantum gravity papers that were posted on another thread, and I've got a question about Berman's calculations
http://arxiv.org/pdf/gr-qc/0605063v3.pdf
The total energy of closed or flat (if finite) universe sums up to zero in GR.
I'm not seeing a cosmological constant in that paper, and the identities look to me as if they won't work if you add "dark energy". Is that the case?
Space news on Phys.org
No, it works the same with a cosmological constant. Since a CC would also contribute a negative pressure, you can subtract this, leaving the equations the same. See Berman's comment about this in that paper:
Notice that the energy-momentum conservation equation does not change even if we add a cosmological constant density, because we may subtract an equivalent amount in pressure, and equation (24) does not change.
The problem is that the equation is for the matter density of the universe. If you model dark energy as a field then that field is going to have energy, and it's not going to zero as t -> infinity.
On the other hand, one thing that I've seen with some quantum gravity papers is that they don't model the cosmological constant as a independent field, but as a characteristic of how gravity behaves. If Berman has that picture in mind, then I see how he gets this result.
Berman has some rather fringish ideas, but, he is not demure.
I don't think it matters. The equation of state for dark energy is [itex] w = -1[/itex]. So, [itex] \rho = -p[/itex]. Therefore, the right side of the equation vanishes, since [itex] \rho + p = 0[/itex] for a cosmological constant. So, it makes no contribution, and can be ignored.
Still not sure...
In the section 2) where he derives the quantities from GR, he doesn't include the cosmological constant in any obvious way.
Now in section 4), in equation 24) he derives the result that in a flat universe that the energy density of the universe with a cosmological constant is constant. That's fine, but in order to then get to result that the energy density of the universe is null he has to argue that the energy of "dark energy field" is zero rather than a positive constant.
Alternatively what you could do define the "energy of the cosmological constant" as the zero level, and then argue that the energy of everything that isn't dark energy is zero relativity to that level.
But I think that what might be happening is that QM and GR views are colliding. In QM, you have a vacuum and then you put fields into that vacuum. Dark energy is thought of as another field, and so it has an energy just like an electron field. In GR, everything is geometry, and asking about the energy of the dark energy field is like asking about the energy of the ether, it doesn't make any sense.
I'm finding it amusing that one of the difficulties is that GR and QM seem to have different views of what is "nothing".
In the first step, he contracts a pseudo-tensor with the stress-energy tensor. Since dark energy can be modeled as just a regular fluid with an equation of state w = -1, the stress-energy tensor should include any contribution from a cosmological constant in some region of space.
Though, I'm not sure of this.
Isn't it? Due to the negative pressure it contributes, it leaves the energy density the same (which is the key equation of his derivation). As I mentioned above, this is because, for dark energy, ##p = -\rho##.
Does that really work, though? It seems a bit more like a 'slight-of-hand' rather than an actual derivation of a zero energy universe to just use different values for the same physics.
Even though they differ conceptually, they are physically equivalent. For some cosmological constant ## \Lambda ##, there is an associated vacuum energy given by
[tex] \rho_{vacuum} = \frac {\Lambda c^{2}} {8 \pi G} [/tex]
So, I don't think that should pose too much of a problem.
FAQ: Berman's zero energy condition for universe
1. What is Berman's zero energy condition for the universe?
Berman's zero energy condition is a theoretical concept proposed by physicist Robert J. Berman. It suggests that the total energy of the universe is exactly zero, meaning that the positive energy of matter is balanced out by the negative energy of gravity. This condition is based on the principle of conservation of energy.
2. How does Berman's zero energy condition affect the expansion of the universe?
Berman's zero energy condition has implications for the expansion of the universe. It suggests that the universe is expanding at an accelerating rate, as the negative energy of gravity is pulling on matter and causing it to move away from each other. This acceleration is thought to be caused by dark energy, a mysterious force that makes up about 68% of the total energy of the universe.
3. Is Berman's zero energy condition widely accepted among scientists?
Berman's zero energy condition is a controversial concept that is still being studied and debated among scientists. While some researchers find it to be a compelling explanation for the behavior of the universe, others argue that it is based on unproven assumptions and does not accurately reflect our observations of the universe.
4. What are some potential implications of Berman's zero energy condition?
If Berman's zero energy condition is proven to be true, it could have significant implications for our understanding of the universe. It could help us better understand the mysterious dark energy and dark matter, and potentially lead to new insights about the ultimate fate of the universe.
5. How can Berman's zero energy condition be tested or observed?
Currently, there is no direct way to test or observe Berman's zero energy condition. However, scientists are exploring ways to measure the total energy of the universe and study the effects of dark energy and dark matter, which could provide evidence for or against this theory. Additionally, further research and advancements in technology may eventually allow us to directly observe and test this concept.
