Bernoulli Equation and Leakage in a Pipe
In summary, the conversation discusses the Bernoulli Equation and its application to a scenario where fluid is leaking from a pipe in a ditch. The equation predicts that, at a certain height, the fluid will stop leaking back into the pipe due to the higher velocity inside causing lower pressure. However, in reality, this does not always occur due to factors such as the pressurization of the fluid inside the pipe and alternative paths for the fluid to flow. A more rigorous mathematical explanation is also provided. The conversation also touches on similar phenomena observed in a bunsen burner and a carburetor.
Zahid Iftikhar
121
24
Hi boneh3ad
Your discussion on Bernoulli Equation was very impressive and helped me a lot to understand this rather complicated equation. I have a question which puzzles me a lot when I want to solve it using Bernoulli equation.
Here is the statement.
" If there is some fluid flowing thru a pipe and it develops a leak, the fluid starts oozing out of it. If this pipe is in some ditch and the fluid keeps collecting in the ditch and finally covers the whole pipe upto some height, then according to Bernoulli equation, there should not be any further leakage. The velocity being higher inside the pipe will cause low pressure inside than outside and the fluid will leak back to the pipe."
But this does not happen. I am sure I am mistaken somewhere. Please guide on this.
Regards
Zahid
So my first question here would be why do you think this doesn't happen?
Zahid Iftikhar said:
H If this pipe is in some ditch and the fluid keeps collecting in the ditch and finally covers the whole pipe upto some height, then according to Bernoulli equation, there should not be any further leakage. The velocity being higher inside the pipe will cause low pressure inside than outside and the fluid will leak back to the pipe."
You are assuming the answer to your question (pressure outside > pressure inside) for no apparent reason, but it isn't true: the pressure inside the pipe is not lower than the pressure outside. If it was, you'd never get water to your house! The pipe is under pressure because you need pressure to both move the water and to overcome the friction inside the pipe from the moving water. So it will always need to be higher than the pressure outside the pipe.
In any case where the pressure is lower inside the pipe than outside the pipe, fluid will flow back into the pipe. The reason this does not happen often in real life (i.e. in the case of a burst oil pipeline or water line) is because fluid inside pipes is often pressurized, so that even though its pressure is lower when it is flowing than when it is still, the pressure inside the pipe is greater than the pressure outside the pipe. Also, fluid leaking from a pipe often has somewhere else it can go to avoid building up pressure around the pipe; it can flow into the ground around it or can find some path away from the pipe. In a situation where fluid did build up around a pipe, it would reach a height where the pressure at the level of the leak was equal to the pressure inside the pipe at the leak. The system would then be in equilibrium, and no more fluid would leak out of the pipe.
For a more rigorous mathematical treatment of the problem, consider this. Bernoulli's equation is $$p + \frac{1}{2}\rho V^2 + \rho g h = constant$$
Now, consider the two primary regions in this problem: the fluid inside the pipe, and the fluid outside the pipe. Inside the pipe, the fluid has a velocity ##V##. Let us say, for the sake of simplicity, that ##\rho = constant## and at the leak ##h = 0##. Then inside the pipe, we have $$p + \frac{1}{2}\rho V^2 = const.$$
Outside the pipe, ##V = 0##. Since we are dealing with a continuous fluid, we may equate Bernoulli's equation from both regions: $$p + \frac{1}{2}\rho V^2 = p + \rho g h$$
At equilibrium, no fluid can pass into or out of the pipe, so the two static pressures ##p## must be equal. Subtracting ##p## from both sides of the equation, $$\frac{1}{2} \rho V^2 = \rho g h$$
Dividing by ##\rho##, $$\frac{1}{2} V^2 = g h$$
So the height to which the fluid rises depends only on the velocity of the fluid inside the pipe.
Now, if the fluid is accelerated to a higher velocity, static pressure will initially drop inside the pipe, and the condition ##p_1 = p_2## will no longer be true (where ##p_1## is the static pressure inside the pipe and ##p_2## is the pressure outside the pipe). In this case, fluid will enter the pipe until Bernoulli's equation is again satisfied (specifically until ##p_1 = p_2## again). If the fluid is decelerated to a lower velocity, then static pressure will increase inside the pipe (##p_1 > p_2##) and fluid will again leak out of the pipe until equilibrium is reached.
I think you missed the part where he said the leak causes the water to pool until its height above the pipe makes its hydrostatic pressure greater than that in the pipe.
But the same is happening in a bunsen burner. When the air rushes thru the cylinder covering the jet, the air from outside gets into the cylinder and mixes with the gas. Same also happens in a carburetor.
I mean I observe in real life it does not happen. But according to the law, it should happen. :biggrin::biggrin:
But every fluid moves under some pressure difference. Then what is the Bernoulli equation about? Under what circumstances is it applicable? Same thing happens in a Bunsen burner where gas is pushed by the jet, but it creates low pressure inside and as a result air enters thru the vent into the cylinder and mixes with the gas.
And I am wondering where you have observed it not happening. I would propose that any situation where this is not happening therefore doesn't represent the situation you've outlined since what you've ruined is correct. However, note that really the pipe would leak and fill up its surroundings until the hydrostatic pressure outside matched the pressure inside, and at that point it would just stop leaking. It wouldn't typical overshoot. If it did overshoot, water would leak back into the pipe.
Well, what you say is in my observation. I don't mean that situation. I am referring to the time when leaked fluid just covers the pipe and same fluid is present outside and inside the pipe. It is the situation before the equilibrium point.
Right.
Bernoulli's principle is applicable along a streamline. It only applies to points along a flow that are connected (an element of the flow will travel from one place to the other you are comparing).
To say it another way, pressure in faster moving fluid is lower than the same fluid, in the same system, previously moving slower. You can't ignore the rest of the dynamics of the system when analyzing it!
Another key assumption typically in Bernoulli's equation/principle is lack of friction, which creates losses and requires higher pressures in real-world systems. You can add friction to Bernoulli's equation as a separate term, but that is a little deeper than a lot of people get.
No, I didn't miss that, I contradicted it: it is an assumption and it is almost certainly false in most real-world situations. The OP is talking about pseudo-real-world situations, and that scenario is usually not possible. A domestic water pipe would need something on the order of 150 feet of water pooled above it to equalize the pressure!
The bunsen burner pipe is open, so the gas is no longer pressurized: it is at atmospheric pressure and moving, causing entrainment.
There is actually a style of water pump called an eductor that works on this principle, so it is possible to make it happen, you just have to get the pressure in the pipe down to enable it. A normal domestic water pipe though is under too much pressure to enable this to happen.
Either way, the key is knowing the pressure inside the pipe and outside the pipe. You can't just assume that because the water is moving the pressure will be "low".
Related to Bernoulli Equation and Leakage in a Pipe
1. What is the Bernoulli Equation?
The Bernoulli Equation is a fundamental principle in fluid mechanics that describes the relationship between the velocity, pressure, and height of a fluid moving in a closed system.
2. How is the Bernoulli Equation used in pipes?
In pipes, the Bernoulli Equation is used to calculate the flow of a fluid and the pressure changes that occur as a result of this flow. It helps in understanding the behavior of fluids in pipes and predicting potential issues such as leakage.
3. What is leakage in a pipe?
Leakage in a pipe refers to the unintentional loss of fluid through cracks, holes, or other openings in the pipe. It can occur due to various factors such as high pressure, corrosion, or damage to the pipe.
4. How does the Bernoulli Equation relate to leakage in a pipe?
The Bernoulli Equation can be used to calculate the pressure changes that occur in a pipe due to fluid flow. If the pressure exceeds the strength of the pipe, it can cause leakage. The Bernoulli Equation can also be used to predict potential locations of leakage in a pipe.
5. How can leakage in a pipe be prevented?
Leakage in a pipe can be prevented by using high-quality materials for pipe construction, regular maintenance and inspections, and appropriate pressure and flow control systems. The use of the Bernoulli Equation can also help in identifying and addressing potential issues before they lead to leakage.
  • Mechanical Engineering
  • Mechanics
