sci0x
- 83
- 5
- Homework Statement
- An enclosed hot water tank is filled to a height of 4 m with water at a temperature of 70°C.
The pressure in the head space is 0.2 bar g. The 50 mm diameter outlet from the bottom of
the tank is closed off by a butterfly valve. If this valve was suddenly opened to allow the
contents of the tank to discharge to the atmosphere, calculate stating all assumption, the
initial discharge velocity of water from the tank.
If the discharge outlet was increased to 100 mm what effect would that have on the initial
discharge velocity? Explain why and show your reasoning.
Data
Density of water at 70°C = 978 kg m-3
Gravitational acceleration g = 9.81 m s-2
1 bar = 10^5 Pa
- Relevant Equations
- Bernoulli Equation
Hi there, I'm doing a past exam paper Q and i'd like some help.
Assumptions are: The velocity in the tank is negligible and the hydrostatic head is 4m.
Pressure in the vessel:
Gauge pressure
1 bar g = 10^5 Pa
0.2 bar g = 20,000 Pa
Hydrostatic Pressure: (4)(9.81)(978) = 38,376.72 Pa
Absolute Pressure = 20,000 Pa + 38.376.72 Pa = 58,376.72 Pa
Atmospheric pressure = 1.01 x 10^5 Pa
My Calcs:
Bernoulli Eq to solve for velocity:
P1+1/2ρ⋅V^21+ρ⋅g⋅h1= P2+1/2ρ⋅V^22+ρ⋅g⋅h2
58376.72 Pa + 1/2(978)(0^2) + (978)(9.81)(4) = 1.01 x 10^5 Pa + 1/2(978)(v^2) + (978)(9.81)(0.05^2)
96753.44 = 101023.9855 + 489V^2
-4270.545 = 489V^2 (The figure on the left is negative, so must be gone wrong)
8.7332 = v^2
2.955 m/s = v
Gauge pressure
1 bar g = 10^5 Pa
| = | 58376.72 Pa |
= | 0 | |
= | 4 m | |
= | 1.01 x 10^5 Pa | |
= | X | |
= | 0.05 m |
8.7332 = v^2
2.955 m/s = v
