Bernoulli's equation and high velocity flights
In summary, Bernoulli's equation is a conservation-of-energy equation that is simplified for compressible flow. It doesn't apply to supersonic flights, and so the generation of lift at supersonic and subsonic speeds in supersonic aircraft is unknown.
waynetan
why can't we use bernoulli's equation for high velocity flights ? what changes when air is compressed ? does density change ?
Science news on Phys.org
Welcome to PF!
Hi waynetan ! Welcome to PF! :smile:
Yes, "compressible" means that its density changes, and that change of density either consumes or liberates energy. Since Bernoulli's equation is a conservation-of-energy equation, that change in energy has to be taken into account.
(Also, Bernoulli's equation only applies to non-viscous flow.)
From the PF Library on Bernoulli's equation …
Bernoulli's equation for steady compressible inviscous flow:
kinetic energy per mass plus potential energy per mass plus enthalpy per mass is the same (is conserved) along any streamline of a flow.
Bernoulli's equation along any streamline of a steady non-viscous flow with variable internal energy (and therefore compressible):
[tex]P\ +\ \frac{1}{2}\,\rho\,v^2\ +\ \rho\,g\,h\ +\ \rho\,\epsilon\ =\ constant[/tex]
or:
[tex]\frac{1}{2}\,\rho\,v^2\ +\ \rho\,g\,h\ +\ \text{enthalpy per unit mass}\ =\ constant[/tex]
[itex]\epsilon[/itex] is the internal energy per unit mass, or specific internal energy (s.i.e)
Incompressible flow:
Incompressible flow is flow whose density is constant along any streamline. In such flow, internal energy may be omitted from Bernoulli's equation (in other words, enthalpy per unit mass may be omitted, and replaced by pressure).
For incompressible flow, internal energy per mass is constant, and so for steady inviscous flow, pressure plus the external energy density must be constant along any streamline:
[tex]P\ +\ \frac{1}{2}\,\rho\,v^2\ +\ \rho\,g\,h\ =\ constant[/tex]
waynetan said:
What changes when air is compressed? does density change ?
There is a form of Bernoulli's equation that handles compression and expansion. The density changes, lower during expansion, greater during compression. Since pressure is energy per unit volume, as opposed to energy per unit mass, it's affected by density. The terms in Bernoulli's equation include a pressure term, and two other terms multiplied by density (instead of mass).
Why can't we use bernoulli's equation for high velocity flights?
Bernoulli is a simplied model that doesn't deal with factors like turbulent flow. It doesn't account for the internal energy of the eddies in a turbulent flow. It doesn't account for temperature changes due to compression or expansion of air. It doesn't deal with supersonic flows that involved shock waves. The more generalized Navier Stokes equations handle most of this, but generally they can't be solved, so an airfoil model uses some simplication of Navier Stokes.
since the Bernoulli's equation does not apply to supersonic flights, then how is lift generated at supersonic and subsonic speeds in supersonic aircraft with thin airfoil ?
At a macroscopic scale, lift is generated when air is accelerated downwards (and drag is generated with air is acclerated forwards). Bernoulli doesn't explain how pressure differentials around a wing are created by the interaction between the wing and the air, only how the air responds internally once the pressure differentials exist. Bernoulli is mostly about the obvious fact that air will accelerate from higher presssure zones to lower pressure zones, and Bernoulli's equation approximates the relationship between speed and pressure (and optionally density) during this transition, ignoring issues like turbulence.
There are many web sites that describe how wings generate lift, with some conflictling view points and various levels of detail. This site does a good job of explaining lift without getting too carried away with details. There are plenty of other good web sites as well, but this one is a good starting point, and includes a pair of diagrams showing how the air is affected as a wing travels through it.
http://www.avweb.com/news/airman/183261-1.html
FAQ: Bernoulli's equation and high velocity flights
What is Bernoulli's equation and how is it related to high velocity flights?
Bernoulli's equation is a fundamental principle in fluid dynamics that describes the relationship between pressure, velocity, and height in a fluid. It states that as the velocity of a fluid increases, the pressure decreases. This principle is crucial in understanding the lift force that allows airplanes to fly at high speeds.
How does Bernoulli's equation explain the lift force in high velocity flights?
In high velocity flights, the air travels faster over the curved top surface of an airplane wing than the flat bottom surface. According to Bernoulli's equation, this results in a lower pressure on the top of the wing compared to the bottom. This pressure difference creates an upward force, known as lift, that allows the airplane to stay airborne.
Are there any limitations to Bernoulli's equation in explaining high velocity flights?
While Bernoulli's equation is a useful tool for understanding lift in high velocity flights, it is not the only factor at play. Other factors, such as the shape and angle of the wing, also contribute to the lift force. Additionally, Bernoulli's equation assumes that the fluid is incompressible, which is not always the case in high velocity flights.
Can Bernoulli's equation be used to predict the lift force in all high velocity flights?
No, Bernoulli's equation is most accurate for subsonic speeds, which are speeds below the speed of sound. At supersonic speeds, the behavior of the fluid becomes more complex and Bernoulli's equation may not accurately predict the lift force.
How does the concept of airfoil shape relate to Bernoulli's equation in high velocity flights?
The shape of an airfoil, or the cross-section of a wing, is designed to maximize the lift force in high velocity flights. This shape is based on Bernoulli's equation, as it is designed to create a pressure difference between the top and bottom of the wing to generate lift. The precise shape of an airfoil is crucial for efficient flight at high speeds.
