Bernoulli's equation applicability question....
In summary, the three terms in Bernoulli's equation add to the same constant for any two points along the same streamline if the fluid is stationary, incompressible, and inviscid. However, if the fluid is also irrotational, the three terms add to the same constant for any pair of points in the fluid, even if they are not on the same streamline. This is because a flow with zero curl has the same total pressure everywhere, and the only way for pressure to fluctuate is through velocity gradients. This condition is common in steady, inviscid flows. Total pressure is the sum of static and dynamic pressure, and is constant in situations where Bernoulli's equation applies.
fog37
1,569
108
Hello,
I just want to make sure I am on the right track: the three terms in Bernoulli's equation add to the same exact constant for any two points along the same streamline if the fluid is:
  • stationary
  • incompressible
  • inviscid
However, if the fluid is also irrotational, the the three terms add to the SAME constant for any pair of points in the fluid. Is that correct?
(exception: if the fluid is not irrotational but the streamlines derive from a region, upstream, of uniform flow, then the Bernoulli trinomial is equal to the same constant for every spatial point).
Am I correct?
Likes falconwords
The flow need not be stationary, just steady. Other than that, this looks correct.
Thanks cjl. But what is the difference between stationary and steady?
For "stationary" I mean that the local fluid properties (density, velocity, etc.) at any point in the fluid do not change over time, hence are time invariant. I thought steady and stationary were synonyms...
Glad you confirm that the Bernoulli trinomial is equal to the same constant even for pairs of points that are NOT on the same streamline as long, as the flow is also irrotational, so points on different streamlines can have the same constant. Almost everywhere (books, web, etc.), I always find that the constant is the same only for points on the same streamline...not sure why they don't include the irrotational condition to make the Bernoulli trinomial more general...
Stationary is zero velocity. Steady is constant velocity (at a given point).
As Russ said, stationary means the whole flowfield has zero velocity. Steady just means that the flowfield is not time-dependent (so the velocity is constant at any single point in space).
Thanks!
I still find very interesting that if the flow has zero curl (irrotational), then Bernoulli's equation can applied to any pair of points in the flow (not just pairs of points on a streamline). Why is that?
Most textbooks skip this important detail. Why? Is it really hard for a steady, inviscid flow to also be irrotational?
Fundamentally, it's because the flow then has the same total pressure everywhere. If the flow has rotation, the point in the middle of the rotation has a lower pressure than the points around it, even though it is not moving at a higher velocity, but if there's no rotation anywhere in the flow, the only way for the pressure to fluctuate is for there to exist velocity gradients associated with it, as described by Bernoulli. As for whether this is a difficult condition, it's actually pretty common, at least if you ignore the effects of the boundary layer.
ok. So velocity gradients imply the presence of curl (even if the streamlines are perfectly straight lines).
What do you mean by "total" pressure? I know we often distinguish between "dynamic" and "static" pressures. Static pressure is called static even if the flow is truly moving. It is just measured in a direction other than the direction of motion of the flow...Is that correct?
No, you can have velocity gradients without curl (and you frequently do). Curl implies pressure gradients without necessarily having associated velocity gradients. Total pressure is just static plus dynamic, and is constant for situations where bernoulli's relation applies.
FAQ: Bernoulli's equation applicability question....
What is Bernoulli's equation?
Bernoulli's equation is a fundamental principle in fluid mechanics that relates the pressure, velocity, and elevation of a fluid at any given point. It states that as the velocity of a fluid increases, the pressure decreases, and vice versa.
When is Bernoulli's equation applicable?
Bernoulli's equation is applicable to inviscid, incompressible, and steady flow of fluids. It is also valid for fluids with constant density and negligible changes in elevation. In real-world scenarios, it can be applied to many situations, but it may not provide accurate results in some cases.
Can Bernoulli's equation be applied to all types of fluids?
No, Bernoulli's equation is only applicable to incompressible fluids, meaning that the density of the fluid remains constant. It is not valid for compressible fluids, such as gases, or for fluids with varying densities.
Is Bernoulli's equation applicable to all types of flow?
No, Bernoulli's equation is only applicable to steady flow, which means that the fluid properties do not change with time. It is not valid for unsteady or transient flow, where the fluid properties may vary over time.
What are the limitations of Bernoulli's equation?
Bernoulli's equation has some limitations, including the assumption of inviscid and incompressible flow, which may not be true in real-world situations. It also does not account for energy losses due to friction and turbulence. Additionally, it is only valid for one-dimensional flow and cannot be applied to complex flow patterns.
