Bernoulli's equation not constant?
In summary: W}##are both 1 atm.In summary, the pressure in the tube at the height of the bottom of tank A is greater than the pressure in the tube at the height of the bottom of tank B. This is due to the weight of the water column in tank A plus the weight of the water column in the tube.
n0083
Suppose there are two tanks, tank A and tank B, of equal size and both are very large.
Suppose the bottom of tank A is at an elevation that is higher than the top of tank B.
Suppose there is a very small tube relative to the size of the tanks that connects the bottom of tank A to the bottom of tank B.
Suppose tank A and tank B are both half full of water.
Suppose the tube is completely full of water.
Take point 'a' as the top of the water surface in tank A and take point 'b' to be the top of the water surface in tank B.
Suppose point 'a' has an elevation that is a height, h, meters greater than point 'b'.
Then, points 'a' and 'b' are at a pressure of 1 atm and the velocity, v, of the decrease in the water level in tank A equals the velocity of the increase in the water level in tank B.
Bernoulli's Equation would seem to give the inconsistent equation.
##P_{atm} + \rho g h + \frac{\rho v^2}{2} = P_{atm} + \rho g 0 + \frac{\rho v^2}{2} \implies ##
##\rho g h = 0 \implies ##
##h = 0 ## contradiction.
where ρ is equal to the density of water.
Where is my mistake?
Thanks to the community in helping me understand the limitations and consequences of bernoulli's equation.
The pressure difference between the bottom of tank A and the bottom of tank B will lead to water flow, which leads to friction. The water flow will reach an equilibrium where this friction exactly cancels the power gained from water flowing down a non-zero h.
Why should ρ not be equal instead to the density if AIR.
Afterall, you seem to be calculating the difference in air pressure between surface a and b.
Patm(a) ≠ PPatm(b)
Thanks for your assistance.
I do not think the pressure at the bottom of tank A and tank B are the same.
I do recognize that water will flow from tank A to tank B. I am troubled with why the equation (as I've tried to apply it) provides a contradiction in an otherwise
seemingly simple example. It would seem that the pressure at the bottom of tank B would be greater than the pressure at the bottom of tank A. This would be due to
the weight of the water column in tank A plus the weight of the water column in the tube (i.e. the total water column elevation from the water line in tank A to the
bottom of tank B). However, I thought the pressure at the water line in tank A would be equal to the pressure at the water line in tank B (assuming that the extra column of air pressure
of length h, would be negligible). It is this aspect which must not be correct. That is, the pressure at water line in tank B, must not be equal to the pressure at
the water line in tank A. I assumed because both water lines were exposed to air that their pressures had to both be equal to P_atm. I realize this is incorrect.
The pressure at the water line in tank A is P_atm. The pressure at the water line in tank B, P_b, is P_atm + pgh. This could be determined from the Bernoulli Equation.
P_atm + pgh + pv^2/2 = P_b + pg0 + pv^2/2 ==>
P_atm + pgh = P_b
Because the pressure at the water line in tank B is P_atm + pgh > P_atm, then the water line in tank B will increase in elevation.
Thanks for assisting me in thinking this through.
Again: You forgot to include friction.
Let hA = height of upper surface of water above ground in tank A and hB = height of upper surface of water above ground in tank B, and let hW = height of upper surface of water above the bottom its tank for either tank.
Assume that the tube connection to tank B is sealed off. Rearranging the terms in Bernoulli's equstion and eliminating the velocity term, the pressure in the tube at height of the bottom of tank A
##P_a = P_{atm} + \rho \ g \ {hW}##
and the pressure in the tube at the height of the bottom of tank B (remember the tube is sealed off from the bottom of tank B)
##P_b = P_{atm} + \rho \ g \ ( {hW} + {hA} - {hB}) ##
So Pb is greater than Pa. Once the seal between the tube and the bottom of tank B is removed, the higher pressure at hB results in water flowing into to the bottom of tank B. Once a flow exists, then friction in the tube results in pressure decreasing as it flows through the tube, but the pressure at the outlet at the bottom of tank B will continue to be greater than the pressure at the bottom of tank B, and the flow continues until the height of the upper surface of the water in tank A or the tube (if tank A is emptied) equals the height of the upper surface of the water in tank B.
Related to Bernoulli's equation not constant?
1. What is Bernoulli's equation and why is it important?
Bernoulli's equation is a fundamental principle in fluid dynamics that relates the pressure, velocity, and height of a fluid. It is important because it helps us understand the behavior of fluids in various situations, such as in pipes, airplanes, and weather patterns.
2. Why is Bernoulli's equation sometimes not constant?
Bernoulli's equation is based on the assumption of a constant flow and constant fluid properties. However, in real-world situations, these conditions may not hold true. Factors such as turbulence, viscosity, and compressibility can cause variations in the pressure, velocity, and height of a fluid, leading to a non-constant Bernoulli's equation.
3. How does the shape of an object affect Bernoulli's equation?
The shape of an object can impact Bernoulli's equation by changing the flow of the fluid around it. For example, a curved surface can create areas of high and low pressure, altering the velocity and height of the fluid. This, in turn, affects the constant values in Bernoulli's equation.
4. Can Bernoulli's equation be used for all types of fluids?
No, Bernoulli's equation is only applicable to incompressible fluids, meaning that their density remains constant regardless of changes in pressure or temperature. This means that Bernoulli's equation cannot be used for gases, which are compressible and have varying densities.
5. How does the presence of external forces affect Bernoulli's equation?
External forces, such as gravity or an applied force, can alter the flow of a fluid and thus impact Bernoulli's equation. For example, an object moving through a fluid will create a pressure differential, affecting the velocity and height of the fluid. In these cases, Bernoulli's equation may not be constant due to the influence of external forces.
  • Mechanics
22K
  • Mechanics
