Bernoulli's equation/pressure question
In summary, the task is to calculate the pressure difference between the two ends of a capillary tube through which water is flowing at a specific volume flow rate and temperature. The viscosity of water is also given. The attempt at a solution involved using the second equation for difference in pressure, but this yielded a result of zero. Using the first Bernoulli equation was not feasible due to missing variables. However, it is suggested to take into account the length of the capillary tube and calculate the change in gravitational potential energy, which will cause a change in pressure. Additionally, it is important to consider the effects of viscosity on the flow and modify the Bernoulli equation accordingly.
Senya
Water at 20°C flows through a capillary tube with an inside radius of 0.17 mm and a length of 5.9 cm. If the volume flow rate through the capillary is 1.9 cm3/s, what is the pressure difference between the two ends of the capillary? Give your answer in kPa. The viscosity of water at 20°C is 1.0 x 10-3 Pa s.
P(1) + 1/2pv^2 = P(2) + 1/2pv^2
(p1-p2) = 1/2pv2^2-1/2pv1^2
i tried using the second equation for difference in pressure but what i get is zero which is unfortunately wrong. Aside from that, using the bernouli's equation number 1 requires for variables i don't have.
Hi, Senya, and welcome to PF!
The Bernoulli equation assumes incompressible flow, and, if the inside radius of the capillary tube is constant, the velocities at the start and end points will be the same. Try assuming the capillary tube is vertical and use its length to calculate the change in gravitational potential energy, which will cause a change in pressure.
Which variables don't you have?
Also, remember that Bernoulli's equation is valid only for incompressible and inviscid flows. The viscosity of water is not zero, so there will be some friction losses as water flows through the capillary tube. You must account for these friction losses by modifying the Bernoulli equation.
Related to Bernoulli's equation/pressure question
1. What is Bernoulli's equation?
Bernoulli's equation is a fundamental principle in fluid dynamics that relates the pressure, velocity, and height of a fluid at a specific point in a flow. It states that the total energy of a fluid remains constant along a streamline, meaning as the velocity increases, the pressure decreases and vice versa.
2. How is Bernoulli's equation derived?
Bernoulli's equation is derived from the conservation of energy principle, where the total energy of a system remains constant. This equation is based on the work of Swiss mathematician Daniel Bernoulli, who discovered the relationship between pressure and velocity in a fluid in the 18th century.
3. Can Bernoulli's equation be applied to all fluids?
Yes, Bernoulli's equation can be applied to all fluids, including liquids and gases. However, it is most accurate for incompressible fluids such as water and air at low speeds.
4. What are some real-world applications of Bernoulli's equation?
Bernoulli's equation has various real-world applications, including in aviation, where it is used to explain the lift force on an airplane's wings. It is also used in the design of pipes and pumps, as well as in the study of blood flow in the human body.
5. Are there any limitations to Bernoulli's equation?
Yes, there are limitations to Bernoulli's equation. It assumes that the fluid is ideal, meaning it has no viscosity or turbulence. It also assumes a steady flow and neglects external forces such as gravity. In addition, it is only accurate for incompressible fluids at low speeds.
