Bernoulli's law for water coming out of a faucet
In summary, the problem involves filling a 25-L bucket in 0.5 minutes using a faucet with a radius of 1.0cm located 2.0m above a pipe with a radius of 3.0cm. The equations used include the continuity equation and Bernoulli's law, and the solution involves finding the gauge pressure at the pipe entering the building. The correct equation to use is the Conservation of Energy equation, which states that the total energy at a point in the fluid is constant. The given problem requires the use of the gravitational potential term in the equation.
smeiste
36
Water is supplied to a building through a pipe of radius R = 3.0cm. In the building, a faucet tap of radius r = 1.0cm is located 2.0m above the entering pipe. When the faucet is fully open, it allows us to fill a 25-L bucket in 0.5 minutes. What is gauge pressure in the pipe entering the building? Assume no other faucets are opened during the experiment.
ΔV/Δt = A*v
A1v1 = A2v2
p1 + 1/2ρ(v1^2) = p2 + 1/2ρ(v2^2) (Bernoulli's law)
pgauge = p - patm
Using the first two equations I have determined that v1 = 0.3 m/s and v2 = 2.7 m/s. Now I am unsure how to apply Bernoulli's law when I am missing one of the pressures. When I try to use atmospheric pressure (101325 Pa) as one of the pressures, I do not get the correct gauge pressure, which is 23 kPa. I really just need a push in the right direction! Thank you.
I would use atm pressure as the value for the pressure leaving the faucet. Since it hits the air as it exits. Is that what you attempted? Also remember that Bernoulli's equation will give you the absolute pressure. Did you subtract the atmospheric pressure from that to get the gauge pressure?
The velocity as it enters at the bottom is v1=.3 m/s and the velocity as it exits the faucet is v2=2.65 m/s; I get the same thing...
h1=0
h2=2m
Your form of Bernoulli's EQ seems to be missing a gravitational potential term. This is where the 2 meter height comes into play.
Since the pressure coming out of the faucet is just atmospheric you can just solve for the difference P_1-P_2 that's the gauge pressure. That's what I did and I got the 23kPa. Make sure you take the height into account too; as saladsamurai pointed out you left those PE terms out of your equation.
I'm actually preparing for an exam on this stuff myself.
okay, now I see. so patm + ρgh + 1/2ρ(v1^2) = p2 + 1/2ρ(v2^2)? Would that be the formula?
haha yes it is. Thank you! I think that form of the equation is a combination of Bernoulli's law and Pascal's Law
NO! It is not. (Unless you already did some simplifications. Read on just to make sure you understand the equation properly.)
The correct equation is:
[tex]\frac{v^2}{2} + gz + \frac{p}{\rho} = \text{constant}\qquad(1)[/tex]
This is a statement of the Conservation of Energy. It say that for an incompressible, inviscid flow,the total energy at a point in the fluid (along a stream line) is the same every where. Meaning that the energy at point 1 along a streamline is the same as at point 2 along the streamline. The form of (1) that you would use is:
[tex]\frac{v_1^2}{2} + gz_1 + \frac{p_1}{\rho}=
\frac{v_2^2}{2} + gz_2 + \frac{p_2}{\rho}\qquad(2)[/tex]
where z1 and z2 are the elevation of the fluid at each point. Though you were not given the elevation of each point, you were given the difference which is all that you need since you can group the terms in (2) in such a way that there will be a (z2-z1) term. And you know that z2-z1 = 2 meters.
Okay, thank you for the formula. It's not something that has ever been introduced in class though. I will bring it up with my professor. Thanks!
My guess is that when he introduced Bernoulli's principle, it was in an example. In many cases, we can neglect the difference in elevation. In high velocity flows, it should be clear that the energy contribution due to the kinetic energy term v2/2 will likely be much more important than that of the gravitational potential gz. In the given problem, they want you to use the gravity term because it is not negligible. But definitely bring it up with your professor. It is like that other student have the same confusion if he presented it that way.
Related to Bernoulli's law for water coming out of a faucet
1. What is Bernoulli's law for water coming out of a faucet?
Bernoulli's law for water coming out of a faucet states that as the velocity of a fluid increases, the pressure exerted by the fluid decreases. This means that as water flows out of a faucet, the pressure at the opening of the faucet decreases due to its increased velocity.
2. How does Bernoulli's law apply to water coming out of a faucet?
Bernoulli's law applies to water coming out of a faucet because the water gains velocity as it flows down through the faucet, causing a decrease in pressure at the opening of the faucet.
3. Why does water flow faster when the faucet is partially closed?
According to Bernoulli's law, as the cross-sectional area of a pipe decreases, the velocity of the fluid flowing through it increases. When a faucet is partially closed, the cross-sectional area of the opening decreases, causing the water to flow faster due to the decrease in pressure.
4. Does the height of the faucet affect the water flow according to Bernoulli's law?
Yes, the height of the faucet does affect the water flow according to Bernoulli's law. As the height of the faucet increases, the potential energy of the water also increases, which can lead to a higher velocity and lower pressure at the opening of the faucet.
5. How does air pressure affect the flow of water from a faucet?
Air pressure does not directly affect the flow of water from a faucet. However, changes in air pressure can cause variations in the pressure of the surrounding environment, which can indirectly affect the flow of water from a faucet by altering the pressure differential between the inside and outside of the faucet.
