Bernoulli's Principle applied to Blood Pressures at different heights.
In summary, we will construct a simple model of the circulatory system to investigate the rate at which cuts bleed. The model assumes that blood is a Newtonian fluid at all length scales and that the effects of viscosity can be ignored. A large artery with a diameter of 7mm and a peak velocity of 0.15 m s−1 feeds into a network of capillaries with an area approximately 400 times larger. Using the formulas discussed, we can determine the blood velocity in the artery at different points, the maximum velocity of blood flow from the severed artery, the blood velocity in a capillary, the blood pressure in the capillary net, and the blood velocity leaving the wound. The solutions for these are 7.
KatieKT
We will construct a simple model of the circulatory system to investigate the rate at which cuts bleed. In this model we will assume that blood is a Newtonian fluid at all length scales so that the equations of fluid flow which we have been studying will apply. We will also assume that the effects of viscosity may be ignored.
A large artery has a diameter of 7mm and carries blood which flows with a peak velocity of 0.15 m s−1. This vessel eventually feeds a network of capillaries which together have an area approximately 400 times that of the large artery which feeds into them. In this model, the capillaries are identical to each other and have a diameter of 7.5 μm.
(a) Suppose that the diastolic blood pressure is 130 mmHg at the level of the heart and the blood velocity in the large artery at the heart is 0.15 m s−1. What is the blood velocity in the artery at a point 1 m below the heart? (The density of blood is 1050 kg m−3).
(b) If the artery is severed at a at a point 1m blowthe heart, what is the maximum velocity of blood flow from the artery?
(c) What is the blood velocity in a capillary in the capillary net at this point (1m below the heart)?
(d) What is the blood pressure in the capillary net at this point (in mmHg and with the assumptions discussed above)?
(e) If a capillary is severed, what is the blood velocity leaving the wound? (again on the basis of this model)
Related Formulas- P+1/2 pv² + pgh
Attempted Solution:
A)Constant = P+1/2 pv² + pgh
= 17.32 + 1/2(1050)(.15)² + (1050)(-9.81)(1)
=17.32 + .118 - 10.3
= 7.138m/s
Or my other solution is:
A1V1= A2V2
V2= A1V1/A2
= ((∏0.0035²)(0.15))/ ∏0.000375²
=13.06m/s
I'm thinking that these are the two ways to solve A) but why are they not the same ansewr? Should I use one formula instead of the other?
B) Vmax = √(2gh)= √(2x1050x-9.81x1)= 14.01m/sC) Vc = A1V1/A2= ((∏0.0035²)(0.15))/ ∏0.000375² =13.06m/sD) Pc = P +1/2 pv² + pgh= 130+1/2(1050)(13.06)²+(1050)(-9.81)(1)= 130 + 1.742 - 10.3= 120.45mmHgE) Vwound = Vc = A1V1/A2= ((∏0.0035²)(0.15))/ ∏0.000375² = 13.06m/s
Related to Bernoulli's Principle applied to Blood Pressures at different heights.
1. What is Bernoulli's Principle?
Bernoulli's Principle is a fundamental concept in fluid dynamics that states that as the velocity of a fluid increases, its pressure decreases.
2. How does Bernoulli's Principle apply to blood pressures at different heights?
In the human body, blood pressure is affected by gravity, meaning that blood pressure will decrease as the height above the heart increases. This is due to the fact that as blood flows downward, its velocity increases, causing a decrease in pressure according to Bernoulli's Principle.
3. What is the significance of understanding Bernoulli's Principle in relation to blood pressure?
Understanding Bernoulli's Principle in relation to blood pressure is important for medical professionals in determining the appropriate treatment for patients with high or low blood pressure. It also helps in understanding the effects of altitude and physical activity on blood pressure.
4. How does Bernoulli's Principle explain the difference in blood pressure between standing and lying down positions?
When a person stands, their blood pressure is lower in the legs compared to the heart due to the effects of gravity. This causes blood flow to increase and pressure to decrease, in accordance with Bernoulli's Principle. In a lying down position, the effects of gravity are lessened, resulting in a more equal distribution of blood pressure throughout the body.
5. Are there any exceptions to Bernoulli's Principle in relation to blood pressure?
Bernoulli's Principle is a general concept and there may be exceptions in certain medical conditions. For example, in certain heart conditions, the velocity of blood flow may decrease while the pressure remains high. However, in most cases, Bernoulli's Principle accurately explains the relationship between blood pressure and velocity at different heights.
  • Biology and Medical
