How Does Bernoulli's Principle Explain Everyday Phenomena?
In summary: The higher pressure of the wind pushing on the back of the sail pushes the boat forward.In summary, the reason for windows shattering during high winds is due to the difference in pressure between the outside and inside of the window, not the speed of the wind. The same principle applies to an umbrella breaking in high winds. In the case of a sailboat, the wind hitting the sail causes a change in pressure, resulting in the boat moving in the direction of the wind.
whereami
Hello,
I am a student taking Conceptual Physics in College. We have just completed going over Bernoulli's Principle of lift. Please bear with me on this as it will most likely seem elementary to most of you. Below are several claims that I've heard and that my logical reasoning tells me to be incorrect. If you may be so kind, please help a frustrated student out by helping me understand any of these concepts.
Claim #1: The reason why windows shatter during high winds is because the pressure of the wind on the outside portion of the window (i.e. the area being "hit" with the wind) is much lower than the pressure of the wind on the inside of the window (the area not being directly affected by wind). The high-pressure on the inside thus "pushes" the window and cracks it.
My logic #1: It is not the high pressure of the inside portion of the window that cracks the window. It is the speed of the air being blown by the wind. That is to say, wind, just as any other object, is subject to Newton's First Law of motion. The air in motion has a tendency to stay in motion just like any other object (e.g. a rock thrown at the window has nothing to do with air-pressure, but rather, the direct force exerted by the rock).
Question #1: Does the air not exert a direct force upon the window on impact? If I were to take a very powerful fan and start blowing air parallel to the window (also lowering the pressure[?]) would the window also shatter?
Claim #2: It is said that the reason for why an umbrella sometimes brakes (by being inverted) during a high wind is because the pressure blowing on top of the umbrella is lower than the pressure directly below the umbrella, which exerts a great force at pushing the umbrella up and breaking it.
My Logic #2: I don't have as much of a problem with this statement, except if it weren't for one thing. See question.
Question #2: What if I take a fan and blow directly on top of the umbrella (not sideways)? Although I have never conducted this experiment, I have reasonable doubt that the umbrella will also "come up" upward. Is this true or not?
Question #3: Take a small ship and attach a sail to it. Now turn the sail in the direction of the wind. The effects will be obvious. The ship will move in the direction of the wind. Why? According to Bournelli's Principle, the pressure is actually lower at the side of the sail where the wind makes the impact. Should not the higher pressure from the other side push the sail in the opposite direction of the wind?
Thank you in advance for taking the time to look over these questions.
Hi whereami, welcome to PF!
Re the first case:
The way the wind is blowing would make a difference if the window blows out or in.
If the pressure is lower outside because of wind blowing tangent to the pane or a sudden loss of atmospheric pressure or whatever, the window will blow out if the difference is enough to overcome the structural strength of the glass.
If the wind is blowing directly into the window, you will have a stagnation point somewhere on the window, and as a result, a localized high pressure.
Remember, that ANY point force is merely an idealization of a pressure distribution. In the real world there are no point forces because there are no points. Even throwing a rock at a window breaks the window because the pressure distribution of the impact overcomes the window's local structural strength.
Similar situation for case 2. Wind blowing at the bottom of an umbrella slows down to a stop, increasing the pressure. The other side remains at atmospheric pressure (disregarding turbulence).
Case 3: I think you have it backwards. Wind hitting the sail slows down, therefore the pressure increases.
Hello,
Thank you for sharing your questions and thoughts on Bernoulli's Principle of lift. I can understand how this concept may seem confusing at first, but hopefully I can provide some clarification for you.
In regards to claim #1, you are correct in your logic that it is not the high pressure on the inside of the window that causes it to shatter. It is actually the difference in pressure between the inside and outside of the window that creates a force, known as the wind load, which can cause the window to break. This wind load is a combination of the pressure difference and the speed of the air hitting the window. So, in your example with the fan blowing parallel to the window, the window may not shatter because there is no significant pressure difference being created.
For claim #2, the umbrella may break if the pressure on top of it is lower than the pressure below it, causing a net force to push it up. However, if you were to blow air directly on top of the umbrella, the pressure would likely increase on top and decrease below, causing the umbrella to stay in place or even be pushed down. This is because Bernoulli's Principle only applies to an ideal fluid flow, which is not the case with a fan blowing air directly on the umbrella.
As for question #3, the sailboat is able to move in the direction of the wind because of the shape and angle of the sail. The curved shape of the sail causes the air to flow faster on one side and slower on the other, creating a pressure difference that generates a force in the direction of the wind. This is known as the Bernoulli effect and is similar to how an airplane wing creates lift.
I hope this helps to clarify some of your questions about Bernoulli's Principle. It is a complex concept, but with some practice and further study, I am sure you will gain a better understanding of it. Good luck with your studies!
FAQ: How Does Bernoulli's Principle Explain Everyday Phenomena?
What is Bernoulli's Principle of lift?
Bernoulli's Principle of lift is a scientific law that states that as the speed of a fluid (such as air) increases, the pressure exerted by the fluid decreases. This principle is used to explain how lift is created in objects such as airplane wings.
How does Bernoulli's Principle of lift work?
The shape of an airplane wing, called an airfoil, causes air to move faster over the top of the wing than the bottom. This creates an area of low pressure above the wing and an area of high pressure below the wing. The difference in pressure creates an upward force, or lift, on the wing.
What is the relationship between air speed and pressure according to Bernoulli's Principle of lift?
Bernoulli's Principle states that as the speed of a fluid, such as air, increases, the pressure exerted by the fluid decreases. This means that as air moves faster over the top of an airplane wing, the pressure above the wing decreases, creating an upward force, or lift, on the wing.
How does Bernoulli's Principle of lift explain flight?
Bernoulli's Principle of lift explains how the shape of an airplane wing creates a difference in air pressure, resulting in an upward force, or lift, that allows the airplane to fly. This principle is also used in other flight-related objects, such as helicopter blades and even bird wings.
Are there any limitations to Bernoulli's Principle of lift?
Bernoulli's Principle of lift is a simplified explanation of lift and does not take into account other factors that contribute to flight, such as the angle of attack and air turbulence. Additionally, this principle does not fully explain lift in all situations, such as when flying at supersonic speeds or in non-aerodynamic objects.
9K
