Bertrand's and Earnshaw's theorems contradiction
In summary, the first theorem states that gravitational forces (1/r potentials in general) are able to produce stable orbits, whereas the second excludes stability. Can somebody help me to clear this out?
Trifis
167
I think the title is self-explanatory. The first theorem states that gravitational forces (1/r potentials in general) are able to produce stable orbits, whereas the second excludes stability! Can somebody help me to clear this out?
Earnshaw's theorem talks about static configurations.
In Earnshaw's theorem there is not a minimum for the potential. In Bertrand's theorem close orbits are excecuted around a point of stability (like the oscillation).
I need something more elaborate please.
static = no movement
orbits = movement
When an orbit has a stable point then the particle can as well stay at this point point forever without losing its dynamical stability.
To contradict Earnshaw all involved particles have to remain static, not just a single one. It applies only to point masses/charges which cannot occupy the same point in space.
Specifically, Earnshaw's Theorem states that in a static situation for pointlike particles, a 1/r potential does not have any maxima or minina (stable points) in an unoccupied region, since the sources themselves occupy space. When dynamics are added into the mix, there is an effective potential from the angular component which pushes away from the source and falls off as 1/r2. For example, with gravity, the potential is a combination of angular repulsion ([itex]\frac{1}{2}\frac{mh^2}{r^2}[/itex]) and gravitational attraction ([itex]\frac{GMm}{r}[/itex]), which gives a total potential of [itex]U=\frac{1}{2}\frac{mh^2}{r^2} - \frac{GMm}{r}[/itex], and a minimum at [itex]r=\frac{h^2}{GM}[/itex].
(h is angular momentum per mass)
Ok therefore it is the extra angular movement which provides the stability of the ORBIT and cannot be found in the static case.
On second thought it can be said that since Earnshaw applies only on 1/r forces (my oscillation argumantion was thereby false) there weren't any equilibrium states Kepler-like orbits first place to debate on in the first place ...
so since Laplace says that there can be no local extrema then a charge at the center of a cube with charges at the 6 corners cannot be in electrostatic equilibrium since then U would be at a minimum? if the potential is like a saddle point for the center charge in a cube then in the xz plane it is at a max and yz it is at a minimum at the same time? (do you calculate the potential by superposition to find the saddle point?)
how do you know that the charge leaks out of every face of the cube?
Griffiths doesn't say that much about this, is it better to read Purcell and Wave Electromagnetics at the same time?
Related to Bertrand's and Earnshaw's theorems contradiction
What are Bertrand's and Earnshaw's theorems?
Bertrand's theorem states that in a system of charged particles moving under the influence of their mutual electrostatic forces, there exists at least one stable circular orbit for every particle. Earnshaw's theorem, on the other hand, states that it is impossible to achieve a stable equilibrium in a system of electrically charged particles using only electrostatic forces.
What is the contradiction between these two theorems?
The contradiction lies in the fact that Bertrand's theorem suggests that there can be stable orbits in a system of charged particles, while Earnshaw's theorem states that stable equilibrium is impossible to achieve in such a system. This raises the question of whether both theorems can be true at the same time.
How can both theorems be true at the same time?
The key to understanding this contradiction is to recognize that Bertrand's theorem only applies to systems with two particles, while Earnshaw's theorem applies to systems with three or more particles. Therefore, it is possible for both theorems to be true simultaneously, as they are applicable to different scenarios.
Is there a way to reconcile these two theorems?
Some researchers have proposed that the contradiction between Bertrand's and Earnshaw's theorems can be resolved by considering the effects of relativity and quantum mechanics on the behavior of charged particles. However, this is still an area of ongoing research and there is no definitive answer yet.
What are the practical implications of these theorems?
Bertrand's and Earnshaw's theorems have important implications in the fields of physics and chemistry, particularly in the study of atomic and molecular structures. They also have applications in the design and stability of electrically charged systems, such as electronic circuits and magnetic levitation devices.
13K
