What Are Some Examples of Symbolic Manipulation Not Included in Calculus?
In summary, there is no single well-defined definition of calculus within mathematics. It is a meta-mathematical term that describes the subject of mathematics and can have different meanings depending on context. In a general sense, it refers to any method of computation or calculation. In the context of college math courses, it specifically refers to the differential and integral calculus, which are methods for approximating and computing functions. However, this narrow definition excludes other forms of analysis and symbolic manipulation that fall under the broader definition of calculus as a frame for calculations.
Jonathan212
198
Not satisfied with the following definition of calculus. What is a better definition? More detailed?
1a : a method of computation or calculation in a special notation (as of logic or symbolic logic)
b : the mathematical methods comprising differential and integral calculus —often used with the
https://www.merriam-webster.com/dictionary/calculus
Within mathematics "calculus" is not a well-defined term. It has no definition.
"Calculus", like "geometry" and "algebra" are meta-mathematical terms that describe the subject of mathematics and, therefore, have a certain imprecision and fluidity.
Likes Stephen Tashi
I'll give this a shot. in a general sense it is true that a "calculus" is just a method of computing or calculating anything. (I believe the root word means pebble or stone, so probably goes back to counting things with a pile of pebbles.) If you mean it in the context of usual college math courses, at least in the US, where it refers specifically to the differential and integral calculus, then differential calculus is a method of approximating functions by linear functions, as well as drawing conclusions about a function based on a knowledge of its best linear approximation. The integral calculus may be described as a method for computing average values of functions, with respect to some concept of size or measure, such as length or area. It also allows the computation of length and area, as well as volume,...
We use analysis (real, complex, vector) for what in English is calculus, and use calculus only for a certain frame, like the predicate calculus in logic.
I don't think anyone can give an answer that will satisfy you without knowing why you are "not satisfied with the following definition of calculus". What do you think is wrong with it?
That it is too vague. The college math definition is a lot better and then we add predicate logic to the same bucket as integrals and differentials and it seems less elegant. Not even sure what predicate logic is and what it is doing in the same branch as integrals.
To narrow calculus to differential and integral calculations is the error here. Analysis is a lot more than just this, but it includes these. On the other hand, calculus means simply a framework for calculations. It doesn't say which kind of calculations. So the implicit meaning differential and integral takes away the many other frames, which makes no sense.
Analysis in everything about functions on ##\mathbb{R}^n## and ##\mathbb{C}^n##.
Calculus is a frame for calculations, and as such has nothing to do with analysis unless you identify the two, leaving no room for the many other meanings.
Some examples of symbolic manipulation NOT included in calculus?
Related to What Are Some Examples of Symbolic Manipulation Not Included in Calculus?
1. What is the best definition of calculus?
The best definition of calculus is a branch of mathematics that deals with the study of continuous change and motion. It involves the use of mathematical concepts such as limits, derivatives, and integrals to analyze and solve problems related to rates of change and accumulation.
2. Why is calculus considered an important field of study?
Calculus is considered an important field of study because it has a wide range of applications in various fields such as physics, engineering, economics, and even biology. It provides a powerful tool for understanding and predicting the behavior of complex systems and processes.
3. What are the two main branches of calculus?
The two main branches of calculus are differential calculus and integral calculus. Differential calculus deals with the study of rates of change and slopes of curves, while integral calculus deals with the accumulation of quantities and the area under curves.
4. How is calculus different from other branches of mathematics?
Calculus is different from other branches of mathematics because it focuses on the study of continuous change and motion, rather than discrete quantities. It also involves the use of limits and infinitesimal calculations, which are not typically used in other branches of mathematics.
5. What are some real-life applications of calculus?
Some real-life applications of calculus include predicting the motion of planets and objects in space, designing bridges and buildings, optimizing production and manufacturing processes, and analyzing economic trends and data. It is also used in medical imaging and modeling biological processes.
  • STEM Academic Advising
