Best Dosimeter for 10 ns Pulse Dose Measurement
  • Thread starter Thread starter Salman Khan
    Pulse Short
The discussion centers on the challenges of measuring 10 ns pulse doses with dosimeters, as traditional dosimeters measure dose over time rather than short pulses. Participants highlight that thermoluminescent dosimeters (TLDs) may be suitable due to their quick response time, while pocket dosimeters based on ion chambers are considered bulky and less precise. Real-time measurement options include scintillation counters, though concerns about their effectiveness for such brief pulses are raised. Geiger counters are deemed unsuitable due to their dead time and potential for continuous discharge under intense radiation. Overall, the conversation emphasizes the need for specialized dosimetry solutions for ultra-short pulse measurements.
Salman Khan
Which type of dosimeter is best for pulse short (duration let say 10 ns) dose measurement purpose?
None? By definition a dosimeter measures dose over time. Or do you mean pulses over time?
10ns pulses sounds.....odd. can you say exactly what the application is?
Let's just say that he has a unique job in the industry... :wink:
https://www.freepik.com/free-photos-vectors/nuclear/9
If I want to measure the dose of FXR machine which may be use for radiography purpose. Such a machine produce output x-ray pulse of ns wedth.
I think a thermoluminescent dosimeter (TLD) would be a good possibility since response time is irrelevant.
Likes Alex A, russ_watters and berkeman
What is your idea about pocket dosimeter based on ion chamber ?
That depends on what you will be using it for; since it is bulky it has low spatial resolution compared to a
TLD for example.
EDIT: to be clear it has to be uniformly irradiated.
If you do not need real-time readings, the old-style photographic film dosimeter may be useful.
For real-time readings, perhaps a scintillation counter would do it.
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC3000535/
(found with:
https://www.google.com/search?hl=en&q=xray+scintillation+dosimeter)
A Geiger Counter can also be used:
https://www.nrc.gov/reading-rm/basic-ref/students/science-101/what-is-a-geiger-counter.html
Other types of instruments can provide an exposure rate (expressed as milliroentgen per hour or mR/hr). These counters must be calibrated to read a particular type of radiation (alpha, beta, gamma, neutron, x-ray) as well as the amount of energy emitted. The reading will only be accurate for that type of radiation and that energy level. And these instruments need to be calibrated regularly to be sure they are providing correct information over time.
Cheers,
Tom
Likes Salman Khan
Hi Tom,
A Geiger counter can't work because a single beta particle would create one electrical pulse with a few microseconds dead time after and a 100ns criticality accident pulse of radiation would create one electrical pulse with a few microseconds dead time.
For a similar reason a commercial scintillation counter would also not work.
Likes Salman Khan
An additional issue with GM counters is that if the pulse is intense enough (which it must be if it is only 10 nsec wide) the radiation may cause the detector to go into a continuous discharge and become unresponsive. An ionization chamber might be possible although ion recombination issues may still be associated with the high-intensity beams.
Likes Alex A and berkeman
  • · Replies 25 ·
  • · Replies 27 ·
  • · Replies 28 ·
  • · Replies 0 ·
