Sean Powell
- 7
Best fit MIN/MAX line through data.
Hello,
I’m working with mechanical fatigue test data. Generally this data falls in a logarithmic curve relating load to number of fatigue cycles. This data tends to be somewhat erratic so there need to be a lot of samples at multiple different loads to achieve anything resembling reasonable predictions.
With that said, the purpose of this fatigue data is to establish a maximum acceptable load/cycle curve rather then a mean load/cycle curve. All of the techniques I can find for establishing best-fit curves specifically work for establishing a mean curve through the center of the data. I want to establish a curve for the minimum least square error where all of the data points are on or ABOVE the line.
Presently I am doing this by re-distributing the data as load/log(10)cycles so I can work with a straight line, selecting a data point by hand, generating a line through this point parallel to the least square line, calculating the least square error and manually playing with the slope to see if this is reasonable. Then I need to reverse this line back into a Log(10) formula.
Every time the data changes I need to manually re-adjust everything. Even this is OK but I’m about to get hit with a LOT more data. Does anyone have a better automated way to do this? Are there any simple formulas for minimum or maximum trend lines? I’m out of college too long for this sort of stuff.
Thanks in advance,
Sean
Hello,
Thanks in advance,
Sean
