Best way to filter NED redshift data
In summary, when creating a plot of redshift vs longitude using a manageable amount of data, it is important to prioritize sources that use direct or indirect methods such as spectroscopy and photometry, and to consider the classification and source of the data to ensure the most accurate measurements.
nearc
i'm using http://ned.ipac.caltech.edu/ui/?q=byparams to extract redshift data. while I'm very happy there is now lots of data available, data requests need to be limited in size or you get an error. i would like to examine the patterns of redshift vs longitude, but that is too much data, i could breakdown the longitude into tiny pieces, maybe 5 degrees at a time, however, even after glued all those sliced together it would be too big for a spreadsheet. i was wondering if redshift data could be ranked in some way so i could choose the "best" data thus downloading a subset of the complete data. i realize some of this ranking might be subjective or at least different people will have different options on what is the most valid data, however, are there some characteristics to look for? for example:
Classified Extragalactic options i could choose between absorption line vs emission line, does one tend to be more precise than the other?
Unclassified Extragalactic options: radio, infrared, visual, UV, x-ray or gamma-ray sources
Components: is a star better than a galaxy?
i realize this is a broad question and a little vague, but the goal is simple how to make a plot of redshift vs longitude with a manageable size of data that will represent the overall patterns of a plot of redshift vs longitude from the complete dataset. the items above are just some of the options if you have a better way to make the data size more manageable let me know
Astronomy news on Phys.org
.In terms of ranking redshift data, the most reliable sources of data are usually those that use direct or indirect methods such as spectroscopy and photometry to measure redshifts. These methods are the most precise and accurate, and have been tested and verified for accuracy. Absorption line spectroscopy is usually considered the most reliable method for measuring redshifts, since it provides an exact measurement of the redshift at a specific point in time as opposed to other methods which may not be as accurate.In terms of classification, galaxies are generally more reliable than stars, since their redshift values tend to be more consistent and can be measured more accurately. However, if you are looking for precision and accuracy, it is important to look at both individual stars and galaxies to ensure that you are getting the most accurate measurements.Finally, it is important to consider the sources of the data when ranking them. Are they from trusted sources? How recently were the measurements taken? Are the measurements supported by other measurements? All of these factors can help you decide which data points are the most reliable.
Related to Best way to filter NED redshift data
1. What is NED redshift data?
NED (NASA/IPAC Extragalactic Database) redshift data is a collection of measurements that indicate the distance between galaxies and Earth, based on the Doppler effect of light. It is an important tool in studying the large-scale structure of the universe and the movement of galaxies.
2. Why is it important to filter NED redshift data?
Filtering NED redshift data is important because it helps to remove any erroneous or incomplete data points, which could lead to inaccurate conclusions. It also helps to identify outliers that may skew the overall results.
3. What is the best way to filter NED redshift data?
The best way to filter NED redshift data is to use a combination of statistical methods and visual inspection. This could involve removing data points that fall outside a certain range, checking for consistency among multiple measurements, and identifying and addressing any potential sources of error.
4. Can filtering NED redshift data affect the results of a study?
Yes, filtering NED redshift data can have an impact on the results of a study. Removing certain data points or outliers can change the overall trends and patterns observed in the data. Therefore, it is important to carefully consider the filtering methods used and the potential effects on the results.
5. Are there any tools or software available for filtering NED redshift data?
Yes, there are several tools and software programs available for filtering NED redshift data. Some examples include the NED Data Services, which allows users to filter and download specific subsets of NED data, and the Python package Astropy, which includes functions for filtering and manipulating astronomical data.
  • STEM Educators and Teaching
  • Astronomy and Astrophysics
24K
