I Best way to fit three functions
  • I
  • Thread starter Thread starter LCSphysicist
    Fit Functions
The discussion focuses on finding the optimal values for variables x, y, z, and t in three highly non-linear functions defined by f, g, and h, given limited data points. The proposed approach involves minimizing the residues for each function simultaneously, potentially using the Lagrangian method to manage the constraints. However, the complexity of the non-linear functions raises concerns about the feasibility and efficiency of coding such a solution. An alternative suggestion is to combine the requirements of all data points into a single equation and apply Newton's approximation method for root finding. Ultimately, defining a clear mathematical criterion for "best fit" is essential for effective minimization.
LCSphysicist
TL;DR Summary
I have basically three set of data, each set corresponding to a function, so that the data should fit the function, and each function is dependent of 4 parameters. How to find the best 4 parameters that fit it?
So I have $$f(x,y,z,t,n) = 0,g(x,y,z,t,n) = 0,h(x,y,z,t,n) = 0 $$ and i need to find the best ##[x,y,z,t]## that fit the data, where n is the variable. Now, the amount of data for each function is pretty low (2 pair for f (that is, two (n,f)), 3 pair for g and another 3 pair for h)
The main problem here is: the functions are highly non-linear. So i have no idea how can i write a program to find the best x,y,z,t!
I have thought of try to simultaneously minimize the residues, for example, for f:
$$R(f) = \sqrt{(f(x,y,z,t,n_1) - y_1)^2+(f(x,y,z,t,n_2) - y_2)^2}$$
(where y is the f obtained on thee data at n_1 (the pair i have cited above))
But this minimization subject to the condition that ##R(g), R(h)## (here, three terms) also be minimum. So maybe i could use Lagrangian method:
$$dR(h) = \lambda dR(g) + \mu dR(h)$$
But this is going to be extremelly massive and tedius to write a code, and the code will take days to run. As i said, the functions are non-linear.
Any method suggestion? or program suggestion?
Mathematics news on Phys.org
Extremely massive and tedious is probably the best you can get. If it was one occurrence, I'd advise WolframAlpha or plot the 3 functions and visually pick the best fit (further improved with Newton's approximation method).
For now I'd advise to combine the requirements for all the data points on f, g and h and rewrite them as ##function - data = 0## and then the square of the left hand side must be minimal for all data points simultaneously: so take the derivative with respect to ##n## of these squares all added up and approximate where this formula in ##n## equals 0 using Newton's approximation method or some better root finding algorithm.
Wiki on Newtons method
You'll need to decide what you consider "best fit". Write that down mathematically as fitquality(x,y,z,t), then feed it in a program for minimization.
The sum of squared residues for all data points (data point minus the applicable function) sounds like a good start.
Likes Maarten Havinga
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
