Best Way to Graph in Polar Coordinates
In summary, the best way to graph in polar coordinates is to plot several points and then make a curve between them, unless the given curve is a standard curve or can be transformed into a standard form. In this case, the curve r = 3 - 5 cos theta was drawn using Maxima and it is recommended to plot some points to ensure accuracy.
Amer
259
what is the best way to graph in polar coordinates say
[tex]r = 3 - 5 \cos \theta [/tex]
is it to plot several points then make a curve between them or ?
Re: Best way to Graph is polar
Hi Amer,
Unless the curve given is a standard curve (circle, ellipse etc) or can be transformed into a standard form, we have to plot it by marking points. I drew your curve using Maxima.
http://imageshack.us/f/337/figure.png/
Sudharaka said:
Hi Amer,
thanks so i need to plot some points. ok
Yes. Try plotting it and see if it really fits the curve I have attached. :)
FAQ: Best Way to Graph in Polar Coordinates
What is the purpose of using polar coordinates for graphing?
Polar coordinates are often used to graph equations or data that involve circular or rotational patterns. They allow for a more intuitive understanding of these types of functions and can also make it easier to identify symmetries and special points on a graph.
How do I convert Cartesian coordinates to polar coordinates?
To convert from Cartesian coordinates (x,y) to polar coordinates (r,θ), you can use the formulas r = √(x²+y²) for the distance from the origin to the point and θ = arctan(y/x) for the angle formed by the positive x-axis and the line connecting the origin to the point.
Can polar coordinates be used to graph 3-dimensional objects?
No, polar coordinates are only used for 2-dimensional graphs. To graph 3-dimensional objects, you would need to use a different coordinate system such as cylindrical or spherical coordinates.
What is the difference between a polar graph and a Cartesian graph?
A polar graph uses polar coordinates, which are based on a distance from the origin and an angle from the positive x-axis, while a Cartesian graph uses Cartesian coordinates, which are based on a distance from the x-axis and y-axis. Polar graphs are typically used for circular or rotational functions, while Cartesian graphs are used for linear functions.
How do I plot points in polar coordinates?
To plot a point in polar coordinates, you first locate the distance from the origin (r) and then rotate that distance by the specified angle (θ) from the positive x-axis. You can then plot the point at the resulting (x,y) coordinates. Alternatively, you can also use the polar gridlines on a polar graph paper to plot the point directly.
