Best way to learn fluid mechanics while in high school
In summary: This is a pretty in-depth answer, so please see the links I provided for more information on potential flow and how to solve specific types of problems.
DylCG10
Hi,
I am a high school student doing a project on fluid dynamics and need to understand the relevant maths so that I can understand how to apply the mathematics of fluid flow (particularly air flow around a cylinder). I have a basic calculus understanding and need to understand the navier stokes equations in depth and any other maths to be able to create a mathematical model of air flow around a cylinder. What is the best and most efficient way to have a mathematical understanding of the fundamentals of fluid dynamics maths in under a month? E.g. through online videos, textbooks (and if so, which textbooks are good that aren't too advanced)?
Your problem will be bridging your calculus to classical mechanics and then to fluid mechanics and learning about partial differential equations along the way.
There are videos on youtube about the Navier-Stokes equation and how folks apply various boundary conditions to come up with a simpler equation to model.
Some history:
Intro to Navier-Stokes:
To give you an idea of the partial differential equations and how the Navier Stokes was derived:
3blue1brown has several video collections that you should check out:
Likes berkeman
Sounds like a pretty challenging (and fun) project. Maybe @boneh3ad has some suggestions on ways to simplify the project to make it more practical to accomplish in that short timeframe...
Likes jedishrfu
DylCG10 said:
I have a basic calculus understanding and need to understand the navier stokes equations in depth... What is the best and most efficient way to have a mathematical understanding of the fundamentals of fluid dynamics maths in under a month?
This is a fool's errand. You won't get this in under a month. Your best bet is to finish 3 years of a BS in one of several flavors of engineering if you want to approach this in an effective, methodical way.
DylCG10 said:
...to be able to create a mathematical model of air flow around a cylinder.
You may be in luck due to this portion of your request. You can get a lot of good information on this topic by first exploring potential flow theory. You won't capture any physics related to viscosity that way, but it is orders of magnitude more straightforward than the Navier-Stokes equations. Whether it is sufficient depends on why exactly you want to do this.
Likes bigfooted, jedishrfu, Delta2 and 1 other person
get a job putting in sprinkler and /or plumbing systems ;)
Or, take swimming lessons.
Studying fluid mechanics itself is very much going in at the deep end.
In the limit case that you are interested in making a small computer program to compute some velocities and pressures around a cylinder without the time to go into the details of partial differential equations, have look at this page:
https://en.wikipedia.org/wiki/Potential_flow_around_a_circular_cylinderThe basic idea behind solving potential flow problems is that you can compute the potential flow around an object by using combinations of simple and well known solutions and add them to get the solution of your more complicated problem. This method is also called a panel method.
Here are some lecture notes that will show you how you can compute some flows around simple objects.
http://web.mit.edu/16.unified/www/FALL/fluids/Lectures/f15.pdf
Please also look into the limitations of potential flow: in models there is usually a trade-off between simplicity and accuracy.
Likes berkeman
It's not the same as a panel method. A panel method is one application of potential flow, but not all potential flow problems use panel methods. Panels are one example of a class of simple solutions you can add together but they aren't the only solution.
Related to Best way to learn fluid mechanics while in high school
1. What is fluid mechanics?
Fluid mechanics is a branch of physics that deals with the study of fluids (liquids and gases) and the forces that act on them. It involves understanding the behavior of fluids at rest and in motion, as well as their interactions with solid objects.
2. Why is it important to learn fluid mechanics in high school?
Learning fluid mechanics in high school can help students develop critical thinking and problem-solving skills that are applicable to a wide range of fields, including engineering, medicine, and environmental science. It also provides a foundation for understanding many everyday phenomena, such as the movement of water and air.
3. What are some ways to learn fluid mechanics while in high school?
There are several ways to learn fluid mechanics while in high school, including taking a physics or engineering course that covers the topic, reading textbooks or online resources, and conducting experiments or demonstrations with simple equipment such as syringes, tubes, and water.
4. What are some common misconceptions about fluid mechanics?
One common misconception about fluid mechanics is that it only applies to liquids, when in fact it also applies to gases. Another misconception is that fluids always flow in a smooth and predictable manner, when in reality they can exhibit complex and chaotic behavior.
5. How can I apply my knowledge of fluid mechanics in high school to real-life situations?
Understanding fluid mechanics can be useful in many real-life situations, such as designing efficient plumbing systems, predicting weather patterns, and developing medical devices. It can also help you make informed decisions about environmental issues, such as pollution control and water conservation.
