Best way to measure period of a pendulum.
In summary, the best position to start timing the period of a pendulum is at the bottom of the swing due to the larger velocity of the bob. It is recommended to wait for a few oscillations to allow the pendulum to settle and use a long pendulum and large mass to increase precision. Possible sources of error include friction, rotation of the bob, and non-linearity of the pendulum's motion. To reduce these errors, smaller oscillations can be used to decrease velocity and maintain planar motion, and a denser bob or counting multiple swings can be used.
TripleB
What position should you start to time the period and why? Should you start to time the period straight away or wait, and if so for how long (how many oscillations)? If the length is fixed should you use a long or short pendulum to increase precision? If the mass is fixed should you use a large or small mass to increase precision? What are possible sources of error and how can they be reduced? A stopwatch is being used to measure the period, and the pendulum models a simple pendulum consisting of a string tied to a heavy spherical bob.
My guesses: start timing at the bottom of the swing because the bob has the largest velocity at this point and hence it will be easier to identify the time when to start/stop. You should wait for a couple of oscillations to let the pendulum 'settle'; the string may not quite be taut upon release or you may introduce some twisting which would quickly dissipate after a few oscillations. You should use as long a pendulum as possible: this increases the period which decreases the relative error in the measurement of the period and the increased length reduces the relative error in the measurement of the length. The mass should be as large as possible to make the pendulum as 'simple-like' as possible (the true period (physical pendulum) depends on the moment of inertia and the simple pendulum is an idealization). Possible sources of error: friction, rotation of bob (i.e. non-planar oscillations), non-linearity of true pendulum (i.e. sin x ~ x but not exactly). For first could use smaller oscillations and hence reduce velocity (frictional force typically proportional to velocity), for second just have to try to keep oscillations planar, and for third use smaller oscillations to make approximation more accurate. Are these correct? And what other possible solutions are there?
That seems to be garbled, the last parts of each being swapped.
Not sure that makes it simple. Maybe you mean as dense as possible.
Another way is to use a bob like a yoyo on a string. The bob will not rotate on its centre as it swings.
Only if you mean air friction (drag).
You did not mention counting many swings.
Related to Best way to measure period of a pendulum.
What is a pendulum?
A pendulum is a weight suspended from a fixed point that swings back and forth under the influence of gravity.
Why is it important to measure the period of a pendulum?
Measuring the period of a pendulum is important because it can be used to determine the length of the pendulum and the strength of gravity at a specific location.
What is the best way to measure the period of a pendulum?
The best way to measure the period of a pendulum is by counting the number of swings it makes in a certain amount of time, typically 1 minute, and then dividing by the number of swings to get the average period.
What factors can affect the period of a pendulum?
The period of a pendulum can be affected by the length of the pendulum, the mass of the weight, and the strength of gravity. Air resistance and friction can also have small effects on the period.
How can the period of a pendulum be used in scientific research?
The period of a pendulum can be used in scientific research to study the effects of gravity and other forces on objects, to measure the strength of gravity at different locations, and to make precise time measurements in experiments.
