UserNameHere
- 3
I want to produce a large amount of rust for a thermite reaction, at least a 12 oz can full, in a relatively short period of time. By short period of time I mean maybe a week. Here is a post from another forum:
"What you're all missing is this: rust is oxidation -- it's a galvanic process. It needs oxygen from the air, and water to conduct electricity. Immersing the steel wool in water only slighly increases the rate at which it will rust. It will still take forever and a day.
If you put the steel wool in a solution of bleach and vinegar, however, it will rust in seconds. Why? Because bleach is a potent oxidizer, and readily accepts electrons from the iron. By itself, this reaction would also quickly reach equilibrium by itself, and not make much rust.
If you add vinegar (ethanoic acid), however, the acid rapidly snaps up the highly basic product of the oxidation reaction, and neutralizes it. The result is a reaction that can proceed quickly, and does not reach equilibrium until all of the bleach and all of the vinegar is consumed."
It appears that he contradicted himself in paragraph 2/3. He says bleach, vinegar, and steel wool will not produce much rust because it will reach equilibrium. Then, he says adding vinegar will produce rust rapidly and the result does not reach equilibrium until all of the bleach and all of the vinegar is consumed. Does he mean adding MORE vinegar to the bleach/vinegar mixture will produce more rust, or does he mean vinegar alone will produce more rust or...? I tried bleach/vinegar with steel wool and it didn't work very well. However, this was steel wool that most likely had a protective coating. I am willing to get some pure steel wool (my chemistry teacher has plenty) and try this again if this method will work. But first, which method would work better...just the vinegar, or the vinegar and bleach. Oh, and by the way, I AM aware that bleach/vinegar produces chlorine gas or chlorine-like gases that are dangerous. I will be doing this outside and I didn't die last time, so I think I'll be fine.
EDIT: Should I take a piece of iron to a grinder and just use iron filings instead of steel wool? I believe using steel wool would result in more impurities in the rust, would it not?
-James
-James
