Beta decay fundamental question
In summary, beta decay results in the emission of a beta particle, which attracts electrons to it and results in the atom losing an electron.
Smed
36
Can someone please clarify beta decay for me. As I understand it, in B- decay, a neutron turns into a proton, electron, and anti-neutrino, then the electron and anti-neutrino are ejected. But from this example, it looks like there are two additional electrons as a result of decay.
19/8 O -> 19/9 F + 0/-1 e + 0/0 v
You start with 8 electrons in the Oxygen atom, then a new electron is created from beta decay which would give 9 electrons. On the right side of the equation Fluorine has 9 electrons plus the beta minus electron = 10. Where is the 10th electron on the right hand side coming from?
Thanks
This notation refers to nuclei, not atoms. The 9 means there are 9 protons.
When the oxygen-19 (neutral atom with 8 bound electrons) decayed to fluorine-19, the fluorine atom still had only 8 bound electrons.
Adding to Avodyne's comment, the number of electrons in a neutral atom is proportional the atomic number, Z, which gives the number of protons (+charges) in the nucleus. The 19 in those equations is the atomic mass in integer atomic mass units (amus). The electron mass to proton mass is ~1/1836, so it's departure from the nucleus does not substantially change the atomic mass.
A beta particle would slow down near (within cm) the original nucleus, and there would be a cascade of electrons along the ionziation path. Change in Z is balanced by that free electron so the net charge between O-19 and F-19 doesn't change on the atomic level.
See this regarding beta decay - http://hyperphysics.phy-astr.gsu.edu/hbase/nuclear/beta.html#c2
This helps, but I'm still a little confused. I thought that the electrons were always equal to the atomic number Z, otherwise how can you know how many electrons are in the atom? In other words, if the Fluorine atom from this reaction only has 8 electrons, then how is it distinguishable from 19/9 F which has 9 electrons?
In a neutral state, there are Z electrons (of negative charge) balancing Z protons (positive charge) in the nucleus. With beta decay, the charge of the nucleus increases by 1, so the number of atomic electrons must also increase by 1, to remain neutral.
Usually what happens is the ejected electron (beta particle) slows down by ionization and excitation (by virtue of collisions with atomic electrons). Meanwhile the original atom (from where the beta particle originated) 'steals' an a electron from a neighbor, and there is a cascade until that all the electrons along the ionzation path, including the beta particle, have been reabsorbed into the neighboring atoms.
Similar, when an alpha particle (+2) is ejected, the new nucleus has a new charge (Z(orig)-2), so two atomic electrons are lost. The alpha particle passes through other atoms ionizing and exciting them, until it comes to rest, absorbs two electrons and become a He atom.
Also in the case of positron emission (+ beta), the original nucleus loses a + charge, so it also loses 1 atomic electron. Eventually, the positron annihilates with an electron, again maintaining neutrality. There is a cascade of electrons which migrate to fill the 'holes' in the atoms from the atom which lost its electron in the annhilation process back toward the original atom that emitted the positron.
Related to Beta decay fundamental question
1. What is beta decay?
Beta decay is a type of radioactive decay that occurs when an unstable atom emits an electron or positron in order to become more stable. This process can also result in the emission of a neutrino or antineutrino.
2. What is the difference between beta minus and beta plus decay?
Beta minus (β-) decay occurs when a neutron in the nucleus of an atom is converted into a proton, releasing an electron and an antineutrino. Beta plus (β+) decay, on the other hand, occurs when a proton in the nucleus is converted into a neutron, releasing a positron and a neutrino.
3. How does beta decay affect the stability of an atom?
Beta decay can change the number of protons and neutrons in an atom's nucleus, which can affect its stability. If an atom has too many or too few neutrons compared to protons, it can become unstable and undergo beta decay in order to achieve a more balanced ratio.
4. What is the role of the weak nuclear force in beta decay?
The weak nuclear force is one of the four fundamental forces of nature and is responsible for beta decay. It allows for the conversion of a neutron into a proton (or vice versa) by changing the quark makeup of the nucleus. Without the weak nuclear force, beta decay would not be possible.
5. What is the significance of beta decay in nuclear reactions?
Beta decay plays a crucial role in nuclear reactions by helping to stabilize the nuclei of atoms. It also allows for the creation of new elements and isotopes through the process of transmutation, where one element is transformed into another through the emission of beta particles.
