Beta+ meson, decay - Relativistic kinematics
In summary, the ##B^+## meson decays through the weak interaction. One of its decay channels is . If a ##B^+## is traveling with a total energy of 9.90 GeV, calculate the range of possible energies the produced may have. Justify why the values you calculate are the minimum and maximum possible.
Matt atkinson
116
The ##B^+## meson decays through the weak interaction. One of its decay channels is
may have. (i.e. determine the minimum and maximum values of its energy.) Justify why the values you calculate are the minimum and maximum possible.
Mass of ##B^+## is 5.279 GeV/c2, mass of
is 1.865 GeV/c2,mass of ##\rho^+##is 0.770 GeV/c2
max energy => when ##B^+ \parallel \bar{D^o}## and ##\rho^+## anti parallel to ##B^+##
min energy => when ##B^+ \parallel \bar{D^o}## and ##\rho^+\parallel B^+##
Max
conservation of momentum ; ##E_{\beta}=E_{\rho}+E_{\bar{D}}##
conservation of energy ; ##p_{\beta}=-p_{\rho}+p_{\bar{D}}##
$$E_{\bar{D}}^2=m_{\bar{D}}^2+p_{\bar{D}}^2$$
$$E_{\bar{D}}^2=m_{\bar{D}}^2+(p_{\beta}+p_{\rho})^2$$
$$E_{\bar{D}}^2=m_{\bar{D}}^2+p_{\beta}^2+p_{\rho}^2+2p_{\rho}p_{\beta}$$
$$E_{\bar{D}}^2=m_{\bar{D}}^2+p_{\beta}^2+E_{\rho}^2-m_{\rho}^2+2p_{\rho}p_{\beta}$$
$$E_{\bar{D}}^2=m_{\bar{D}}^2+p_{\beta}^2+(E_{\beta}-E_{\bar{D}})^2-m_{\rho}^2+2p_{\rho}p_{\beta}$$
$$E_{\bar{D}}=\frac{m_{\bar{D}}^2+p_{\beta}^2+E_{\beta}^2-m_{\rho}^2+2p_{\rho}p_{\beta}}{2E_{\beta}}$$
but after this I am not sure how to get rid of the ##p_{\rho}## from the ##2p_{\rho}p_{\beta}}{2E_{\beta}## term.
also to do the case for minimum energy, i would just have ##p_{\beta}=p_{\rho}+p_{\bar{D}}## for my momentum conservation right?
edit;using momentum conservation on the ##p_{\beta}=p_{\rho}+p_{\bar{D}}## term;
$$E_{\bar{D}}=\frac{m_{\bar{D}}^2+m_{\beta}^2-m_{\rho}^2+2p_{\bar{D}}p_{\beta}}{2E_{\beta}}$$
but this doesn't help too much because i still don't know ##p_{\bar{D}}##
You can get rid of the rho momentum in favor of the rho energy by the energy-momentum-mass relation for the rho. You can get rid of the rho energy in favor of the D energy by conservation of energy.
But you are taking a long way around. I would suggest working in the rest frame of the B and then Lorentz boost the result.
Is the way I am doing it correct, but just very long winded?
so consider ##\beta## at rest and then ##\rho## and ##D## would be moving oppositely? and use lorentz transformations to get my result from that?
That is how I would do it (well more or less). You can of course do it just algebraically, but thinking first helps a lot.
I tried to think about the way I did it, I'm just really struggling with relativistic decays or collisions.
Not sure why they don't seem too bad when i study them, just really struggle solving the problem.
My way of doing it, just as you said by changing rho momentum for rho energy and then D energy, resulted in a expression with a ##E_{D}## and a ##\sqrt{E_D}## term which I just figured id done something wrong, didnt think solving an equation that was quadractic in ##\sqrt{E_D}## a good way to solve it.
so i tried the way you suggested with rest mass, and that seemed to work much better (if I've done it right that is).
I end up getting ##E_D=\frac{m_D^2+m_{\beta}^2-m_{\rho}^2}{2m_{\beta}}##
then doing lorentz $$ E_D'=\gamma E_D-\beta \gamma \sqrt{E_D^2+m_{\beta}^2-m_{\rho}^2-2E_Dm_{\beta}}$$
Where ##p_D=\sqrt{E_D^2+m_{\beta}^2-m_{\rho}^2-2E_Dm_{\beta}}## in the rest frame and ##E_D## is the one i calculated for the rest frame?
but when i do this i just get that ##E_D'<m_D## which can't work, that was using the gamma and beta from the rest frame, should it be the gamme and beta from lab frame?
FAQ: Beta+ meson, decay - Relativistic kinematics
What is a Beta+ meson?
A Beta+ meson, also known as a positron, is a subatomic particle with a positive charge and a mass approximately equal to that of an electron. It is the antiparticle of the electron and is denoted by the symbol α+.
How does a Beta+ meson decay?
A Beta+ meson decays by transforming into a proton, a neutrino, and a positron through the weak nuclear force. This process is known as beta decay.
What is relativistic kinematics?
Relativistic kinematics is a branch of physics that studies the motion of objects moving at speeds close to the speed of light. It takes into account the effects of special relativity, such as time dilation and length contraction, on the motion of particles.
How is relativistic kinematics applied to the decay of a Beta+ meson?
Relativistic kinematics is used to calculate the energies and momenta of the particles involved in the decay of a Beta+ meson. It takes into account the mass-energy equivalence and the conservation of energy and momentum in the decay process.
What are the implications of relativistic kinematics on the decay of a Beta+ meson?
The effects of relativistic kinematics on the decay of a Beta+ meson are significant. It can lead to differences in the energies and momenta of the particles involved in the decay compared to non-relativistic calculations. It also allows for the prediction and observation of new phenomena, such as the creation of new particles during the decay process.
