Between 0 and 2pi? So 0 and 2pi consider?
  • Thread starter matttan
In summary, the range between 0 and 2pi is significant in mathematics and trigonometry as it represents a complete circle or revolution in radians. It is used to measure angles and can be divided into smaller units such as degrees or minutes. It is also important in the study of periodic functions and solving equations involving trigonometric functions.
matttan
25
Hi,
I was doing trigonometry and I came across this problem when they said "between".
If they said between 0 to 2pie radians, do they include 0 and 2pie or it is 0 < x < 2pie ?
Thanks
Could be either, but it's usually 0 ≤ x < 2pi.
< is less than so no, but usually there will be a less than or equal to somewhere in there. PI PI PI PI PI. Not pie.
[itex] \Pi \pi [/itex]
"Between" is somewhat ambiguous, so some people will write "strictly between" to indicate that the endpoints aren't included.
I like pie :-p
I would state your assumptions based upon the wording of the question.
For example: My solution for this problem is based on the given condition [itex]0< x < 2\pi[/tex].
If this were an exam question, I would ask the teacher/professor, to clarify their meaning.
Ouabache said:
I like pie :-p
Thanks for all the reply (:
Refer: http://mathworld.wolfram.com/Between.html
" All points on a line segment excluding the endpoints lie between the endpoints. "
So I guess Between 0 and 2Pi means 0 < x < 2Pi?
Because the author is confusing me as for the 1st example, the question states between 0 and 2pi and in his solution he writes 0 < x < 2Pi. And the other qs(example 2). which also says between 0 and 2pi but he writes as 0 <= x <= 2Pi in his solution? Is the author 1st example the correct one?
Lets say if a qs states find all the possible solutions/angle for Sin x = 0 where x is between 0 and 2Pi so if example 1 came in, there will be only 1 solutions which is 1Pi as 0 and 2Pi is out of the range 0 < x < 2Pi. But is example 2 is used, then there will be 3 solutions which is 0, 1Pi and 2Pi as the range is 0 <= x <= 2Pi.
I've always thought that the word "between" meant < or > (unless it said inclusive), while "from...to" had the equal sign below the > and <.
You are correct, the solution depends on interpretation of the given information.
It appears your author is not consistent with the use of "between" in that context.
If you have the opportunity, I would ask your teacher to clarify this sort of ambiguity
before solving your problems. If not, then state your assumptions (as you interpret the question),
and solve the problem based on those assumptions.
FAQ: Between 0 and 2pi? So 0 and 2pi consider?
What is the significance of the range between 0 and 2pi in mathematics and science?
The range between 0 and 2pi, also known as a full circle or 360 degrees, is significant in mathematics and science because it represents a complete revolution or cycle. It is used to measure angles in geometry and trigonometry, as well as in physics and engineering to describe rotational motion.
How is the range between 0 and 2pi related to radians?
The range between 0 and 2pi is equivalent to 2π radians, where π (pi) is a mathematical constant approximately equal to 3.14. Radians are a unit of measurement commonly used in mathematics and physics to measure angles in a circle. One full revolution or 360 degrees is equal to 2π radians.
Can angles outside of the range between 0 and 2pi be measured?
Yes, angles outside of the range between 0 and 2pi can be measured, but they may need to be converted to this range for certain calculations or applications. For example, angles greater than 2pi can be converted to their equivalent value within the range by subtracting 2pi until the angle falls within the range. Similarly, angles less than 0 can be converted by adding 2pi until the angle falls within the range.
How does the range between 0 and 2pi relate to circular functions?
The range between 0 and 2pi is important in the study of circular functions, such as sine, cosine, and tangent. These functions are periodic, meaning they repeat their values every 2pi units. The range between 0 and 2pi allows for the full cycle of these functions to be observed and analyzed.
Are there any real-life applications of the range between 0 and 2pi?
Yes, the range between 0 and 2pi has many real-life applications. For example, it is used in navigation to measure directions and bearings, in engineering to design and analyze rotational systems, and in astronomy to measure celestial positions and movements. It is also used in music to measure the intervals between notes and in art to create symmetrical and geometric designs.
