I Bias in Linear Regression (x-intercept) vs Statistics
In simple regression, the bias represented by the intercept (b) differs from the statistical definition of bias in estimators, which is the difference between the expected value and the true parameter. The model Y = mx + b can produce an unbiased estimator for the population parameter Y, leading to confusion about the term "bias." The terminology used in machine learning may borrow from statistics but does not align perfectly, creating a disparity in understanding. This discrepancy highlights the need for clarity in the use of terms across different fields. The discussion emphasizes that while the concepts may be related, they are not interchangeable.
WWGD
7,733
12,898
TL;DR
Trying to Reconcile two apparently/superficially different usages of the tern "Bias"
Hi,
In simple regression for machine learning , a model :
Y=mx +b ,
Is said AFAIK, to have bias equal to b. Is there a relation between the use of bias here and the use of bias in terms of estimators
for population parameters, i.e., the bias of an estimator P^ for a population parameter P is defined as the difference E[P^]- P?
The two do not seem to coincide as Y^= mx^ +b^ is an unbiased estimator of the population parameter Y . Can anyone explain the
disparity?
Words have more than one meaning. I have never seen bias used with the first meaning, so that appears to be a specialized field of study just “hijacking” terminology from other fields of study. It happens often. I am afraid there is not much justification needed or provided for that type of thing.
Likes FactChecker and WWGD
I think that the two uses are only logically similar in the context of a model where X and Y are known or assumed to be proportional (Y = mx). In that case, b would be a bias due to something.
Likes Dale and WWGD
Hello, I'm joining this forum to ask two questions which have nagged me for some time. They both are presumed obvious, yet don't make sense to me. Nobody will explain their positions, which is...uh...aka science. I also have a thread for the other question. But this one involves probability, known as the Monty Hall Problem. Please see any number of YouTube videos on this for an explanation, I'll leave it to them to explain it. I question the predicate of all those who answer this...
