MHB Bias of functions defined on samples for population
The discussion centers on whether the estimate $$\frac{1}{n} \sum_{i}^{n} f(Xi)$$ is always an unbiased estimator for $$\frac{1}{N} \sum_{i}^{N} f(xi)$$ for any function f. Participants agree that not all functions f yield unbiased estimates, citing the sample variance correction as a key example. It is noted that certain sample parameters may require adjustments to ensure unbiasedness for population parameters. The conversation emphasizes the need for clarity regarding the function f and its implications on bias. Overall, the consensus is that counter-examples exist, indicating that the unbiasedness of the estimate is not guaranteed for arbitrary functions.
mathinator
Let X1, · · · , Xn be a simple random sample from some finite population of values {x1, · · · xN }.
Is the estimate $$\frac{1}{n} \sum_{i}^{n} f(Xi)$$ always unbiased for $$\frac{1}{N} \sum_{i}^{N} f(xi)$$ no matter what f is?My thinking: I don't think all f's are unbiased, because not all sample parameters (ex: variance, or s^2) are unbiased for the population parameter (unless they are corrected for finite population sampling). I am confused if I am interpreting the question correctly, i.e f refers to parameters we can kind about the population :(
Thank you for your help in advance!
Hi mathinator,
Welcome to MHB! :)
Yep I fully agree with your thought process. The sample variance correction is a great example of how this won't work for any arbitrary $f$. I think one counter-example is sufficient to wrap this problem, unless more detail is explicitly specified.
Jameson said:
Hi mathinator,
Welcome to MHB! :)
Thank you for your response!
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
