Biconvex Lens Floating on Mercury
In summary, the lens floats horizontally on the surface of liquid mercury so that its lower surface effectively becomes a spherical mirror. A point object on its optical axis is then found to coincide with its image when it is at a height u above the lens. Determine r and n.Thin lens equation: ##\frac{1}{f} = \frac{1}{u} + \frac{1}{v}##Refraction at Spherical Surface: ##\frac{n_1}{u}+\frac{n_2}{v} = \frac{n_2-n_1}{R}##Lensmakers Equation: ## \frac{1}{f} = (\
Marcus95
50
A thin bi-convex lens with refractive index n has spherical surfaces with equal radii of curvature r and measured focal length f. The lens floats horizontally on the surface of liquid mercury so that its lower surface effectively becomes a spherical mirror. A point object on its optical axis is then found to coincide with its image when it is at a height u above the lens. Determine r and n.
Lensmakers Equation: ## \frac{1}{f} = (\frac{n_2}{n_1}-1)(\frac{1}{R_1}+\frac{1}{R_2})##
I am very uncertain on how to handel the spherical mirror at the back of the lens and I would like to think through the problem before beginning with calculations.
Assuming that f is known, we may use the lens makers equation to express either r or n in the other two variables.
However, I don't know how to use the other information. Had it been a straigth mirror at the other end, I think we migth be able to say that the image is simply reflected and ##u = v##, but I am uncertain about this as well.
My other problem is, that if the ligth never exits the second face of the lens, maybe it cannot be viewed as a full lens? Isn't it then only a refraction at one sperical interface? Or does the spherical mirror compendate for this?
Very Thankful for explanations! :)
Yes.
I'm not quite following you here.
Yes, refraction only occurs at the upper surface of the lens. (How many times does a light ray refract through this surface?) The lower surface of the lens acts like a curved mirror.
I think the problem will simplify for you if you draw a ray diagram for a ray leaving the point object and eventually returning to the same point.
Hmmm. Well, you can try treating the mirror as a special refractive surface where n2 = -n1 (n2 being the index after reflection and n1 being the index prior to reflection).
You can also try Gaussian Reduction if you know how to do that.
The ligth ray refracts twice at that surface. Had there been a straigth mirror behind the first reflecting surface, the ray would have simply been reversed (?) and refracted again. Hence, because we know that the two sides of the lens are of equal radii we could conclude that the distance to the image is of the same magnitude as would have been if there was no mercury, but reversed, ie: ##u = -v##. Now if there is a spherical mirror, I am not sure what happens. I have tried sketching ray diagrams, but the path of the ray seems to depend on n and r so I am not sure what can be said.
Do you mean Gaussian elimination for solving linear equation systems or is this something completely else?
A ray that leaves the object, refracts at the upper surface, and then reflects at the lower surface must return to the position of the object. What is the condition on the angle of incidence of the reflection at the lower surface so that the ray retraces its path back to the object?
Likes Marcus95
Something else. If you don't know what it is, don't worry about it. :biggrin:
Likes Marcus95
Oh, it has to be perpendicular?
Yes. Can you use that information to tell you where the image is located for the first refraction at the upper surface?
I have tried to sketch the situation, but to me it seems to depend on the width of the lens where the ray is hitting the second surface perpendiculary?
The figure shows a couple of rays that leave the object, refract at the upper surface, and then meet the lower reflective surface. The red dotted lines are extensions of rays ##ab## and ##cd## back to the optic axis. So, point ##I## represents the position of the virtual image of the refraction at the upper surface.
You have correctly noted that rays ##ab## and ##cd## meet the lower surface perpendicularly to the lower surface. Use this information to deduce the image distance for ##I## in terms of the radius of curvature ##r## of the surfaces of the lens.
Likes Marcus95
Thank you so much for the picture! I now understand that the image and object distance in order to coincide have to be equal to r, ie ## r = u## if the lens is assumed to be thin. By using the lensmakers equation we can then find ##n = \frac{u}{2f} + 1##. Is that rigth?
Or wait, wouldn't ##r = u## imply that there is no refraction?
Why do you say r = u?
The image distance must equal the object distance for the total system. But, for the refraction at the upper surface, the image distance for this refraction does not have to equal the object distance. But you should be able to deduce the image distance for this refraction using the figure.
Related to Biconvex Lens Floating on Mercury
1. How does a biconvex lens float on mercury?
The biconvex lens is able to float on mercury due to the difference in density between the two substances. Mercury is a very dense liquid, while the lens is made of a lighter material, such as glass or plastic. This creates a buoyant force that allows the lens to float on the surface of the mercury.
2. What is the purpose of performing this experiment with a biconvex lens on mercury?
This experiment is often used as a demonstration of Archimedes' principle, which states that an object will float if it displaces an amount of fluid equal to its own weight. It also highlights the properties of density and buoyancy, and how they affect the behavior of objects in different liquids.
3. Can any other materials besides mercury be used for this experiment?
While mercury is a common choice for this experiment due to its high density, other liquids such as water or oil can be used. However, the results may differ depending on the density of the liquid and the materials used for the lens.
4. How does the shape of the biconvex lens affect its ability to float on mercury?
The shape of the lens is important in determining its ability to float on mercury. The biconvex shape, with two convex sides, helps to distribute the weight of the lens evenly, allowing it to float more easily. A different shape, such as a flat disc, may not be able to float as effectively.
5. Are there any safety concerns when working with mercury in this experiment?
Yes, there are safety concerns when working with mercury. It is a toxic substance and should be handled with caution. Proper safety precautions, such as wearing gloves and working in a well-ventilated area, should be taken when performing this experiment.
