Does a 29 Mountain Bike Wheel Really Offer Less Rolling Resistance?
In summary, the conversation is about the trend of using 29" wheels in mountain biking. Advocates claim that these larger wheels have less rolling resistance and can maintain speed better on varying terrains. However, the increased weight and longer lever of the wheel may actually create more resistance and require more power to accelerate. The main advantage of the larger diameter wheel is the decreased horizontal force when rolling over objects, but this is offset by the added weight and potential for aerodynamic drag at higher speeds. The perceived benefits of the 29" wheel may be due to the reduced angular momentum of a larger diameter wheel.
Nashvis
Could someone aid my understanding of the factors involved here?
The question that has been rolling (pun intended) around my mind is in regards to a trend in mountain biking. The new thing in MTBing is the 29" wheel. Standard wheel diameter is 26". Advocates of the 29er say there is less rolling resistance with the greater diameter wheel which enables them to more easily maintain speeds on trails with varying terrain (rocks, roots, logs, etc..). The thing is, as I understand it, a larger diameter wheel is heavier as are the bike components and bike frame (so as to accommodate a larger diameter wheel). This heavier wheel should create more resistance, requiring more power to accelerate it.
The "lever" of the wheel is also longer on the 29" wheel which would make greater friction.
So is the perceived benefit of the 29"wheel derived from the reduced angular momentum of a larger diameter wheel?
Thanks for any replies.
The main advantage of the larger diameter wheel and tire is the decreased horizontal component of force when rolling over moderately sized objects, rocks, tree roots, small logs, ..., because the angle between vertical and the line between contact point with a small object and the center of the wheel is less with a larger diameter wheel. This angle is = cos-1((radius of wheel - height of object)/(radius of wheel)). The horizontal force is related to the sin of that angle.
Assuming that parameters other than diameter are the same, the wheel weighs more and the angular momentum is higher because of the weight (diameter doesn't directly affect angular inerita, just the radial mass distribution and the amount of mass). The net affect on acceleration is about double the weight of the wheel and tire (if all the mass were at the outer diameter of the tire, then total inertia of such a wheel is double that of of a non rotating mass). A 1 kg tire would have about the same affect on acceleration as a 2 kg mass on the frame.
Rolling resistance would be slightly less with a larger diameter tire, but would be offset by aerodyanmic drag at higher speed.
There are a few factors to consider when it comes to wheel size in mountain biking. First, the larger diameter wheel does indeed have less rolling resistance due to its ability to roll over obstacles more easily. This can be especially beneficial on trails with varied terrain. However, as you mentioned, the larger wheel and accompanying components do add weight to the bike and can require more power to accelerate.
Another factor to consider is the geometry of the bike. The larger wheel size may require a longer frame and different positioning of components, which can affect the overall handling and feel of the bike. Some riders may prefer the stability and momentum of a 29" wheel, while others may prefer the agility and maneuverability of a 26" wheel.
Ultimately, the perceived benefits of a 29" wheel may vary from rider to rider and depend on the specific terrain and riding style. It's important to test out different wheel sizes and see what works best for you. And remember, the most important factor in any bike setup is finding what feels comfortable and allows you to ride with confidence and control.
Related to Does a 29 Mountain Bike Wheel Really Offer Less Rolling Resistance?
1. What is the standard size for a bicycle wheel?
The standard size for a bicycle wheel is 26 inches in diameter. However, there are also other common sizes such as 27.5 inches and 29 inches.
2. How does the size of a bicycle wheel affect the ride?
The size of a bicycle wheel can affect the ride in terms of speed, maneuverability, and comfort. Smaller wheels generally provide quicker acceleration and better maneuverability, while larger wheels offer a smoother ride and higher top speed.
3. Can I replace my bicycle's wheel with a different size?
Yes, you can replace your bicycle's wheel with a different size as long as it is compatible with your bike's frame and other components. It is recommended to consult with a professional bike mechanic before making any changes.
4. What is the difference between 26, 27.5, and 29-inch wheels?
The main difference between these wheel sizes is their diameter, which affects the overall size and ride characteristics of the bike. 26-inch wheels are smaller and offer quicker acceleration, 27.5-inch wheels are a good balance between speed and maneuverability, and 29-inch wheels provide a smoother ride and higher top speed.
5. How do I choose the right wheel size for my bike?
The right wheel size for your bike depends on your riding style and terrain. Smaller wheels are better for technical and agile riding, while larger wheels are more suitable for longer rides and smoother terrain. It is best to test ride different wheel sizes to determine which feels most comfortable for you.
