Big integer arithmetic functions
In summary, the author is looking for algorithms to do big integer calculations, and is considering the two functions that he has found. The first function has a time complexity of O(n), and the second function has a time complexity of O(n^2).
YoungPhysicist
Insights Author
350
203
NOTE:This is not a homework question! This is just a topic that I like very much,but don’t have the programming ability to do many of them.That’s why I post this thread.
C++ is a language without built-in big integer calculation functions,so building ones that can do such job is a great way to practice algorithm testing skills.
For the past couple days,I’ve been searching on the internet for functions capable of doing such calculations,but most of them depends on methods that need to “cout” it’s result digit by digit and unable to return it. That makes them useless when I need to perform several different types of operations in a row on the same input.
So,I would be pleased if I can have functions that can return the result using std::string or int.
The tasks I will need to perform are:
  1. Adding
  2. Subtracting
  3. Multiplying
  4. Dividing
  5. Square root
  6. Exponent
  7. Logarithms
  8. Modulus(the remainder one,not ##|x|##)
I will be appreciated if functions/concepts/great algorithms capable of doing any of the above operations is posted.Thank you!
The big integer that I am talking about are ones over ##10^{500}##
Technology news on Phys.org
The only things I got:
Adding:
Code:
int char2int(char in){
   return int(in-48);
string bint_add(string a,string b){
   string out;
   bool go_on = false;
   int tmp;
   if(a.length() > b.length())
   swap(a,b);
   out.resize(b.length());
   if(a.length() < b.length()){
       string add = "0";
       for(int i = a.length();i<b.length()-1;i++){
           add = "0"+add;
       a = add+a;
   for(int i = b.length()-1;i >= 0;i--){
       tmp = char2int(a) + char2int(b)+go_on;
       if(tmp >= 10){
           go_on = true;
           out = char((tmp%10)+48);
       else{
           go_on = false;
           out = char(tmp+48);
   if(go_on == false)
   return out;
   else
   return "1"+out;
This function have(not sure) a time complexity of ##O(n)##.
modulus:
Code:
int mod(string num, int a) {
    int res = 0;
    for (int i = 0; i < num.length(); i++)
         res = (res*10 + (int)num[i] - '0') %a;
    return res;
Also with a time complexity of ##O(n)##.(I suppose)
Those two functions took me two months.
You will need a User Defined Type or Object that can hold the numbers in your chosen format.
You must decide what format to use. Will you store the numbers in decimal strings, ASCII, or BCD, or convert them to binary and store them in an array of 32 bit integers, so a 32 x 32 multiply will give a 64 bit product, which makes partial products easy.
If you use binary you will need to decide on twos complement or signed data format.
The bottleneck will be converting between human readable ASCII and arrays of binary data, which is a slow base change.
The fastest technique I found was breaking the long decimal number into blocks of 9 decimal digits, then converting them block by block into a compact array of 32 bit unsigned integers, base 1e9. That uses fast modulo 1e9 arithmetic, you keep track of carry and avoid slow base changes. It uses available functions to pack and unpack the blocks in linear time.
Likes YoungPhysicist
I can only help a little, but here goes.
  • bint_add() uses a boolean variable, go_on, in an arithmetic expression. Not a 'Generally Accepted Practice'.
  • I suggest that bint_add() (and any others you implement) operate on "Binary Coded Decimal" (BCD) data rather than ASCII data. That way you don't have to strip and rebuild the ASCII in each operation, you can do it once on input and output.
  • Multiply can be done as in the 'Paper And Pencil' method taught in grade school Arithmetic.
    • apply each digit of the multiplier to the multiplicand (with carry) to a partial product, shifting the partial products as from successive multiplier digits.
      As an optimization to decrease memory usage and complexity, you can add the partial products as you go.
      • If working in Assembly language, another possible optimization is to multiply by one Bit at a time.
      • This has the advantage that testing each bit is a Shift operation (they're fast) and the shifted multiplicand is conditionally added to the partial product (again fast).
  • Divide is again the 'Paper And Pencil' method as in Multiply and the same optimizations can be implemented
The rest of the operations are composed of tha Add, Subtract, Multiply, and Divide
Another optimization is on entry of those 500 digit numbers, you convert them into a binary string or an array of Long Int and operate on those rather than on the individual digits. The drawback is on output you have to convert back to ASCII.
I see Baluncore beat me to this as I was typing. He has some good suggestions there, although a bit more complex to implement.
A thorough explanation of all this is in THE ART OF COMPUTER PROGRAMMING, Volume 2 / Seminumerical Algorithms, Donald E. Knuth. Addison-Wesley Publishing Company, ISBN 0-2-1-03802-1 is from 1969, I believe there are newer versions.
Another good source is Numerical Algorithms in C (Google it)
Cheers, and have Fun!
Tom
Related to Big integer arithmetic functions
1. What are big integer arithmetic functions?
Big integer arithmetic functions are mathematical operations that are specifically designed to handle large numbers that cannot be represented by standard computer data types. These functions allow for the manipulation and calculation of numbers with thousands or even millions of digits.
2. What are some common applications of big integer arithmetic functions?
Big integer arithmetic functions are commonly used in cryptography, where large numbers are used for encryption and decryption processes. They are also used in scientific calculations, financial modeling, and computer graphics.
3. How do big integer arithmetic functions differ from regular arithmetic functions?
Regular arithmetic functions operate on numbers that can be represented by standard data types, such as integers and floating-point numbers. Big integer arithmetic functions, on the other hand, use specialized algorithms and data structures to handle numbers with a much larger range and precision.
4. Can big integer arithmetic functions handle negative numbers?
Yes, big integer arithmetic functions can handle negative numbers just like regular arithmetic functions. They use a sign bit to indicate whether the number is positive or negative.
5. Are there any limitations to using big integer arithmetic functions?
One limitation of big integer arithmetic functions is that they are typically slower than regular arithmetic functions due to the additional computational complexity involved in handling large numbers. Additionally, there may be memory constraints depending on the implementation of the functions.
