Bike and car acceleration physics
In summary, the car and bike will be together after 2.0 seconds when they both have a displacement of 320 meters.
fffff
53
a car accelerates at 1.5ms^-2 from 0 ms^-1 to 30 ms^-1. It then travels at a constant speed of 30 ms^-1.
2.A bike accelerates at 2.5ms^-2 from 0ms^-1 to 20 ms^-1 and then travels at a constant speed of 20 ms^-1
find the instant where there together.
(Both have the same displacement)
all constant acceleration equations
for part one, i can represent the distance as 300+30t.
t=(30-0)/1.5=20s
S=1/2(20)(30) + 30t= 300 +30t
for part 2.
t=(20-0)/2.5=8s
S=1/2(8)(20) + 20t= 80 + 20t
80+20t=300+30t
-220=10t
t=-22s
why is my answer coming in negative. My answer -22 is right but its negative.
This is totally wrong!
Your flaw lies in equating the times when both vehicles start moving with constant speed.
Now, if we let t=0 represent the time when the CAR reaches constant speed, then during the twelve seconds from the BIKE reached constant speed to t=0, the bike has traveled an additional 12*20=240 meters.
Thus, you are to solve
320+20t=300+30t, meaning t=2.
I would like to point out that the negative sign in your answer indicates that the bike and car are not together at the same time. This is because the bike accelerates at a higher rate than the car, so it reaches its constant speed of 20 m/s before the car reaches its constant speed of 30 m/s. Therefore, the bike will have a head start of 2 seconds before the car catches up to it.
To find the exact moment when they are both at the same displacement, we can set the two displacement equations equal to each other and solve for time.
300 + 30t = 80 + 20t
10t = 220
t = 22 seconds
So, the bike and car will be at the same displacement after 22 seconds, but the bike will be 2 seconds ahead of the car.
I hope this helps clarify the concept of displacement and time in relation to acceleration. Keep up the good work in your studies!
FAQ: Bike and car acceleration physics
What is the difference between the acceleration of a bike and a car?
There are several key differences in the acceleration of a bike and a car. The most significant difference is the power source - a bike relies on the rider's muscles to generate acceleration, while a car uses an engine. Additionally, cars have a higher maximum acceleration due to their larger engines and more complex drivetrain systems.
How does the weight of a bike or car affect its acceleration?
The weight of a bike or car can have a significant impact on its acceleration. In general, the lighter the vehicle, the faster it can accelerate. This is because less force is required to move a lighter object, allowing for quicker acceleration. However, other factors such as engine power and aerodynamics also play a role in acceleration.
What role do gears play in bike and car acceleration?
Gears play a crucial role in both bike and car acceleration. In a bike, gears allow the rider to adjust the force and speed of pedaling, which directly affects the acceleration of the bike. In a car, gears allow the engine to operate at different speeds and generate more torque, resulting in faster acceleration.
How does air resistance impact the acceleration of a bike or car?
Air resistance, also known as drag, can significantly impact the acceleration of a bike or car. As speed increases, so does air resistance, which creates a force that opposes the vehicle's motion. This force can slow down the acceleration of a bike or car, especially at higher speeds.
What is the difference between linear and angular acceleration in bike and car physics?
Linear acceleration refers to changes in an object's velocity in a straight line. In bike and car physics, this would refer to changes in speed or direction of travel. Angular acceleration, on the other hand, refers to changes in an object's rotational velocity. In bike and car physics, this would refer to changes in the rotation of wheels or other moving parts.
