Bike vs. Skateboard Acceleration (downhill with no pedaling)
In summary: I'm not very knowledgeable in this field, but I'm really curious about this. I also wasn't sure about which prefix, to use, it's probably more high school level, but oh well.In summary, the bicycle will catch up and surpass the skateboard before the end of the hill, assuming they start at the same point.
keaton
Hi everyone,
My roommate and I were talking about which would win in a short downhill race (with no pedaling from either rider), a bike or a skateboard. Assuming the bike stays in the same gear (2, and 4), and has a wheel diameter of 27", and the skateboard has a wheel diameter of 2.4".
My thinking is that the skateboard will accelerate faster very briefly, as it has the smaller wheels, but then the bike will catch up and surpass the skateboard before the end of the hill, assuming they start at the same point, and the start of the hill.
Can anyone offer me any insight? I'll try to answer any questions for detail that I can.
Thanks!
Keaton
Disclaimer: I'm not very knowledgeable in this field, but I'm really curious about this. I also wasn't sure about which prefix, to use, it's probably more high school level, but oh well.
Why does the gear matter if the rider doesn't pedal?
Makes sense.
keaton said:
but then the bike will catch up and surpass the skateboard before the end of the hill.
Could happen, depending on the surface type, body pose and the length of the race.
For an idealized case, assume the skateboard wheels and bicycle tires are hoops or thin cylinders, in which case the angular (spinning) energy versus ground velocity = 1/2 m v^2 (in addition to the linear kinetic energy, also 1/2 m v^2), regardless of the size (radius) of the wheel or tire. Assuming the skateboard wheels are lighter (less mass) than the bicycle tires, then the skateboard "loses" less energy to angular kinetic energy and it accelerates faster.
In a real life situation, the energy losses related to rolling are greater in a skateboard than a bicycle, a combination of rolling resistance, and bearing losses. A smaller radius wheel / tire will have more issues dealing with imperfections in a road.
Realistically, this pretty much comes down to the friction between the wheels and the ground. Firstly, assuming friction between the ground and the wheels were identical for both the bike and the skateboard, they 'should' both reach the end at the same time(remember, heavy objects fall at the same speed as light ones). Seeing as most skateboards use plastic wheels vs rubber wheels used by bikes, and also seeing that the friction on most bike axles tend to be higher than that of skateboard axles. It would be safe to say that the skateboard would win. But of course there may be some unknown variable I'm not considering here so your best bet would be actually testing the question.
I highly disagree. Bicycles are heavily optimized for low friction losses. For skateboards long distances is secondary. I think it's safe to assume that friction loss is less in a bicycle.
Well, I certainly could be incorrect, but firstly take a look at this. The coefficient of friction between rubber and concrete is 0.65 while the coefficient for plastic hovers somewhere between 0.2-0.55 depending on the type of plastic. So, I must say that the tires of a bicycle are great for going uphill, they are not made for speed, that is what skateboards are for(as far as I know).
As neither the skateboard nor bicycle wheels slide across the surface, those coefficients don't apply really. The friction losses happen at the bearing level at the axle, and there, as a function of size, and rotational speed, bicycle bearings are far superior.
I also must say, it's kinda bizarre to read a statement like "bicycles aren't made for speed". Do you not have a lot of experience with bicycles? They are commonly faster than skateboards.
Likes SirHall
Related to Bike vs. Skateboard Acceleration (downhill with no pedaling)
1. What is the difference in acceleration between a bike and a skateboard going downhill with no pedaling?
The difference in acceleration between a bike and a skateboard going downhill with no pedaling is dependent on several factors such as the weight and size of the rider, the condition and type of the bike or skateboard, and the incline of the hill. Generally, a bike has a higher potential for acceleration due to its larger wheels and gearing system, but a skateboard may have a faster initial acceleration due to its lighter weight.
2. Why does a bike accelerate faster than a skateboard downhill?
A bike has a larger wheel diameter and a gearing system which allows the rider to transfer more force to the wheels, resulting in a higher potential for acceleration. Additionally, the rider's body position on a bike allows for more efficient use of their weight to create forward momentum.
3. Is there a maximum speed difference between a bike and a skateboard going downhill?
There is no specific maximum speed difference between a bike and a skateboard going downhill. It ultimately depends on the factors mentioned in the first question, as well as the skill and experience of the rider.
4. Can the rider's weight affect the acceleration of a bike or skateboard downhill?
Yes, the rider's weight can affect the acceleration of a bike or skateboard downhill. A heavier rider will have more force pushing down on the wheels, resulting in a higher potential for acceleration. However, if the rider is too heavy, it may also slow down the bike or skateboard due to increased friction and drag.
5. How does the incline of the hill affect the acceleration of a bike or skateboard downhill?
The incline of the hill can greatly affect the acceleration of a bike or skateboard downhill. A steeper incline will result in a higher gravitational force, leading to a faster acceleration. However, if the incline is too steep, it may also lead to loss of control and potential accidents for the rider.
20K
  • Mechanical Engineering
  • Mechanics
25K
  • Other Physics Topics
