MHB Bilinear Function and Gramian Matrix
  • Thread starter Thread starter Sudharaka
    Function Matrix
Sudharaka
MHB
Hi everyone, :)
Here's a question which I am not sure whether my approach is correct. My understanding about Bilinear functions and Gramian matrix is limited, so this might be totally wrong. Hope you can provide some insight. :)
Question:
A bilinear function \(f:\Re^3\times \Re^3 \rightarrow \Re \) is given in standard basis \(\{e_1,\,e_2,\,e_3\}\) by the Gram matrix,
\[G_f=\begin{pmatrix}4&3&2\\1&3&5\\3&6&9 \end{pmatrix}\]
Find the left and a right kernel of \(f\).
My Solution:
I would find the left kernel of \(f\) using,
\[\left\{v\in\Re^3:\, \begin{pmatrix}v_1& v_2& v_3\end{pmatrix} \begin{pmatrix} 4&3&2\\1&3&5\\3&6&9 \end{pmatrix} \begin{pmatrix} u_1\\u_2\\u_3 \end{pmatrix}=0\mbox{ for all } \begin{pmatrix} u_1 \\u_2 \\u_3 \end{pmatrix} \in \Re^3 \right\}\]
and the right kernel of \(f\) using,
\[\left\{u\in\Re^3:\, \begin{pmatrix}v_1& v_2& v_3\end{pmatrix} \begin{pmatrix} 4&3&2\\1&3&5\\3&6&9 \end{pmatrix} \begin{pmatrix} u_1\\u_2\\u_3 \end{pmatrix}=0\mbox{ for all } \begin{pmatrix} v_1 &v_2 &v_3 \end{pmatrix} \in \Re^3 \right\}\]
Is this approach correct? Is this how the left and right kernels are given when the bilinear function is represented by the so called Gramian matrix? :)
Sudharaka said:
Hi everyone, :)
Question:
My Solution:
Sure.
Looks good.
You can simplify it a bit though.
You can find the left kernel of \(f\) using:
\[\left\{v\in \mathbb R^3:\, v^T \begin{pmatrix} 4&3&2\\1&3&5\\3&6&9 \end{pmatrix}=0 \right\}\]
That amounts to the same thing.
Do you see why?
Note that these are the eigenvectors of the transpose for the eigenvalue 0.
I like Serena said:
Sure.
Looks good.
Do you see why?
Thanks very much for the confirmation. Of course I see it. Since,
\[\begin{pmatrix}v_1& v_2& v_3\end{pmatrix} \begin{pmatrix} 4&3&2\\1&3&5\\3&6&9 \end{pmatrix} \begin{pmatrix} u_1\\u_2\\u_3 \end{pmatrix}=0\]
holds for each vector \(\begin{pmatrix} u_1\\u_2\\u_3 \end{pmatrix}\) we can choose any two vectors \(\begin{pmatrix} u^1_1\\u^1_2\\u^1_3 \end{pmatrix}\) and \(\begin{pmatrix} u^2_1\\u^2_2\\u^2_3 \end{pmatrix}\) such that,
\[\begin{pmatrix} u^1_1\\u^1_2\\u^1_3 \end{pmatrix}\neq\begin{pmatrix} u^2_1\\u^2_2\\u^2_3 \end{pmatrix}\]
Then,
\[ \begin{pmatrix}v_1& v_2& v_3\end{pmatrix} \begin{pmatrix} 4&3&2\\1&3&5\\3&6&9 \end{pmatrix} \begin{pmatrix} u^1_1\\u^1_2\\u^1_3 \end{pmatrix} = \begin{pmatrix}v_1& v_2& v_3\end{pmatrix} \begin{pmatrix} 4&3&2\\1&3&5\\3&6&9 \end{pmatrix} \begin{pmatrix} u^2_1\\u^2_2\\u^2_3\end{pmatrix}=0\]
Hence,
\[\begin{pmatrix}v_1& v_2& v_3\end{pmatrix} \begin{pmatrix} 4&3&2\\1&3&5\\3&6&9 \end{pmatrix}\left( \begin{pmatrix} u^1_1\\u^1_2\\u^1_3 \end{pmatrix} -\begin{pmatrix}u^2_1\\u^2_2\\u^2_3\end{pmatrix} \right)=0\]
Since,
\[ \begin{pmatrix} u^1_1\\u^1_2\\u^1_3 \end{pmatrix} -\begin{pmatrix}u^2_1\\u^2_2\\u^2_3\end{pmatrix} \neq 0\]
\[\begin{pmatrix}v_1& v_2& v_3\end{pmatrix} \begin{pmatrix} 4&3&2\\1&3&5\\3&6&9 \end{pmatrix}=0\]
Is there a shorter version for this? :)
Looks good! :)
Hmm, a shorter version?
How about:
Let A be the matrix.
Suppose we have a $v$ in the left kernel such that $v^T A \ne 0$.
Then there is a vector $u$ such that $v^T A u \ne 0$
This is a contradiction.
If on the other hand we pick any $v$ such that $v^T A = 0$, then for any $u$ we have $v^T A u = 0$.
Therefore the left kernel is the set of all $v$ with $v^T A = 0$. $\qquad \blacksquare$
I like Serena said:
Looks good! :)
How about:
Thanks very much Serena. :) Indeed this is something much more simpler.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
