Binary search math, log base 2 (n) issues
In summary: The actual number of steps might be 1, or 2, or 3, or 4, or 5, or 6. The point is that 2.807 is an upper bound. Can you give me a set of seven numbers for which the binary search takes only one step?In summary, Binary search requires O(log2(n)) operations in the worst case, where n is the number of elements in the set. This means that the number of operations needed to find an element using binary search will never exceed log base 2 of n. However, in some cases, the actual number of operations needed may be less than this upper bound. The O notation is used to describe the asymptotic
ducmod
86
Hello!
Binary search requires O( log2(n) ) operations in the worst case. My math doesn't add up.
I would be grateful for help.
For example:
Find number 8 in the set 1234578.
The set contains n = 7 elements.
1) take the middle number 4; 4 < 8
2) take the middle number in the right half of the set 7; 7 < 8
3) in the next right half we have only 1 element and it's 8. done.
Thus I've made 3 operations to find the element 8. 2 to the power 3 equals 8, but
there are only 7 elements in the set. Hence, O(log2(n) - 1) operations.
I don't see why it is log2(n).
Thank you!
ducmod said:
Hello!
For example:
Thank you!
See https://en.wikipedia.org/wiki/Binary_search_algorithm#Performance
ducmod said:
Hello!
For example:
Thank you!
Why would you say the set {1,2,3,4,5,6,7,8} has seven elements? Count them: there are eight of them!
Ray, please, take a look at my example, it has 7 elements :) I don't have 6 in the set :)
ducmod said:
Hello!
For example:
Thank you!
You seem not to understand what the O notation means. If x is a variable that can become very large then O(x) is the same as O(x+1) etc.
ducmod said:
Hello!
For example:
Thank you!
The ##\log_2(n)## count is an asymptotic, worst-case bound. For ##n = 7## we have ##\log_2(7) \doteq 2.80735##, and no algorithm can take exactly that many steps.
Right: you got me on that. Good one!
Does it mean that I have to round numbers like 2.80735, and thus get the answer 3? So, the worst case scenario will require 3 steps when n = 7, correct?
See https://en.wikipedia.org/wiki/Big_O_notation.
No: 2.807 is an upper bound on the number of steps, and since the actual number of steps must be an integer, we must have N(steps) ≤ 2.
Related to Binary search math, log base 2 (n) issues
1. What is binary search?
Binary search is an efficient algorithm used to search for a specific value in a sorted list of elements. It works by repeatedly dividing the list in half and comparing the target value with the middle element. This process continues until the target value is found or the list is exhausted.
2. How does binary search work?
Binary search works by dividing the sorted list in half and comparing the target value with the middle element. If the target value is smaller than the middle element, the search is focused on the first half of the list. If the target value is larger, the search is focused on the second half. This process of dividing and comparing continues until the target value is found or the list is exhausted.
3. What is the time complexity of binary search?
The time complexity of binary search is O(log n), where n is the number of elements in the list. This means that the time it takes to complete the search increases logarithmically as the size of the list increases. This makes binary search a very efficient algorithm for searching large sorted lists.
4. What is log base 2?
Log base 2, also known as the binary logarithm, is a mathematical operation that represents the power to which the number 2 must be raised to equal a given number. In the context of binary search, the log base 2 of n represents the number of times the list can be divided in half before it is reduced to a single element.
5. Why is log base 2 used in binary search?
Log base 2 is used in binary search because it represents the number of times the search space can be divided in half. This aligns with the way binary search works, making it a more efficient algorithm compared to other search methods. Additionally, the time complexity of binary search is directly related to the logarithm of the input size, making it a preferred choice for searching large lists of elements.
