Binary System in circular orbit: Separation distance between stars
In summary, the distance between two stars can be calculated using the equation d=1/0.07=14.3 parsecs. The Doppler shift of one star is -0.04, which results in a velocity of 23.4km/s for both stars due to their equal mass. Based on the separation of 0.04nm every 26 years, the full orbital period of the binary system is estimated to be 52 years. However, to fully determine the orbital period, the inclination of the orbital plane to the plane of the sky is needed. With this information, the exercise can be completed.
Thomas Smith
The binary system has a parallax of 0.07 arc seconds. This system consists of two identical stars in circular orbits.
An absorption line at a wavelength of 512nm is seen in the spectra of both stars. This line is split into two components by the orbital motion and has a maximum separation of 0.04nm, which occurs every 26 years.
What's the separation distance between both stars?
Distance to Star System from parallax d=1/p
Doppler Shift Δλ = λ - λ_0
Radical Velocity v_r=Δλ/λ_0 c
Distance is d=1/0.07 = 14.3 parsecs
The Doppler shift of one star is, Δλ = 512 - 512.04 = -0.04
So the radical of the velocity of the star is = (-0.04/512) x (3.00 x 10^5 km/s) = 23.4km/s which is the same for both stars because they have the same mass.
This is as far as I've got.
From the information provided, can you determine the orbital period of the binary system?
Well considering the separation of 0.04nm every 26 years, I believe the full orbit period is 52 years.
If you make an assumption about orientation, you have tangential velocity and period...
Ah sorry, i missed out the inclination. It says the orbital plane is inclined to the plane of the sky by 90 degrees
That was the assumption I'd needed for the problem to make sense. So we are looking at the binary system, "edge on". Does that give you everything you need to finish the exercise?
Related to Binary System in circular orbit: Separation distance between stars
1. What is a binary system in circular orbit?
A binary system in circular orbit refers to two stars that are orbiting each other in a circular path due to their gravitational attraction. This means that the two stars are constantly moving around a common center of mass.
2. How is the separation distance between stars in a binary system determined?
The separation distance between stars in a binary system is determined by measuring the distance between the two stars at their furthest point in their orbit, known as the apastron, and at their closest point, known as the periastron. This distance is also known as the semi-major axis of the binary system.
3. What factors can influence the separation distance between stars in a binary system?
The separation distance between stars in a binary system can be influenced by various factors such as the masses of the stars, their orbital speed, and the gravitational force between them. The closer the stars are to each other, the stronger their gravitational pull, which can result in a smaller separation distance.
4. Can the separation distance between stars in a binary system change over time?
Yes, the separation distance between stars in a binary system can change over time. This can happen due to various reasons such as the stars losing mass, gravitational interactions with other nearby objects, and changes in their orbital speed.
5. How does the separation distance between stars affect their evolution?
The separation distance between stars in a binary system can affect their evolution in various ways. It can determine the length of their orbital period, the amount of mass they exchange with each other, and the type of supernova they may experience. It can also influence the formation and stability of planetary systems around the stars.
  • Astronomy and Astrophysics
  • Beyond the Standard Models
