Binding energy and deuterium nucleus
In summary: This is the number that you should compare to 83250:1.In summary, the average binding energy per nucleon in the deuterium nucleus is 1.12 MeV/c^2, which is equivalent to 1.12 MeV of binding energy. The ratio of this binding energy to the binding energy of the electron is approximately 83250:1, indicating that the neutron is held more tightly than the electron in the deuterium nucleus.
alicia113
103
a) Calculate the average binding energy per nucleon in the deuterium nucleus.
b) The energy that binds an orbiting electron to the hydrogen nucleus is 13.4eV. Calculate the ratio of the binding energy per nucleon to the binding energy per electron in deuterium. Which particle is held more tightly, the electron or the neutron?
Given:
m of deuterium= 1876.12MeV/c^2
m of electron = 0.511MeV/c^2
m of neutron = 939.57 MeV/c^2
m of proton = 938.27 MeV/c^2
*all masses are also given in kg and u, but the example my text gives its answer in MeV/c^2
E=mc^2
[/B]
a) Deuterium-electron=mass of nucleus
(1876.12MeV/c^2)-(0.511MeV/c^2)=1875.609MeV/c^2
Proton+Neutron= (938.27 MeV/c^2)+(939.57 MeV/c^2) = 1877.84MeV/c^2
(proton+neutron)-(mass of nucleus)= (1877.84MeV/c^2)-(1875.609MeV/c^2)= 2.231MeV/c^2
(2.231MeV/c^2)/2nucleons=1.1155
Therefore the average binding energy per nucleon in the deuterium nucleus is 1.12MeV/c^2 (to 3 sigfigs)
I know this is a mass and not an energy but the example earlier in my book gave the average binding energy per nucleon in MeV/c^2, kg, or u so I'm inclined to leave my answer as a mass.
b) I think I should multiply 1.1155MeV/c^2 by 1000000 to eliminate the M:
(1.1155MeV/c^2)x(1000000)= 1115500eV/c^2
Then convert eV/c^2 to kg:
1eV/c^2= 1.78266173 × 10-36 kg
11155500eV/c^2= 1.98855916 e-30kg
E=mc^2
E=(1.98855916 e-30kg)(2.998 e8)^2
E=1.78731777 e-13J
Convert Joules to eV:
1J = 6.24150974 e18 eV
1.78731777 e-13J = 1115556.126eV
Ratio of binding energy per nucleon to electron= 1115556.126eV/13.4eV= 83250:1
Therefore the neutron is held more tightly than the electron as expressed by the ratio 8.32e4:1.
I'm not sure if this is done correctly. Did I convert from MeV/c^2 to eV properly? I think the answer is wrong because my binding energy in both eV/c^2 and eV are both 1.12 e6.
As you pointed out, a value like 1.12 MeV/c^2 has units of mass, not energy. So, really this number is a mass defect. The equivalent binding energy is simply ##E=(\Delta m)c^2##, which in this example would be 1.12 MeV.
Assuming this number is correct (the reasoning seems to be ok), the ratio of this binding energy to the binding energy of the electron is then simply the ratio ##1.12 \times 10^6 / 13.6##.
Related to Binding energy and deuterium nucleus
1. What is binding energy?
Binding energy is the energy that holds the particles within the nucleus of an atom together. It is the amount of energy required to break apart the nucleus into its individual protons and neutrons.
2. How is binding energy related to the stability of an atom?
The higher the binding energy, the more stable the atom is. This is because a higher binding energy means that the nucleus is tightly bound together, making it more difficult to break apart.
3. What is the role of binding energy in nuclear reactions?
Binding energy plays a crucial role in nuclear reactions as it determines the amount of energy released or absorbed during the reaction. In fusion reactions, the combining of nuclei releases large amounts of binding energy, while in fission reactions, the splitting of nuclei absorbs binding energy.
4. What is a deuterium nucleus?
A deuterium nucleus is an isotope of hydrogen that contains one proton and one neutron in its nucleus, as opposed to the usual one proton found in regular hydrogen. It is often referred to as "heavy hydrogen" and is commonly used in nuclear fusion reactions.
5. How does deuterium contribute to binding energy in fusion reactions?
In fusion reactions, deuterium nuclei combine to form a heavier nucleus, releasing a large amount of binding energy in the process. This is because the resulting nucleus is more stable than the individual deuterium nuclei, due to a higher binding energy.
